Hey all,
We’re building a world wide overland member map! We’ve got over 50 members on the map now from Norway to California! The goal is to have as many people as possible on the map to act as a resource for world travelers and overlanders. If you can take a few moments, we’d love to have you on the map!
The Goals:
Build a resource of helpful members worldwide.
build a resource ofΒ overland destinations.
On the Overland Bound website, hover over the social bar at the top of the site to activate the drop-down menu. Go to “Profile -> Edit”. On the next page you will see an item called “location”. Edit that with your location and you will appear on the member map!
Hope to see you on the map!
Check it out:
Member Map
Hello Michael,
Dominic here in southern Cali, just add my location to the Map. I was wondering where we update our Overland Bound Badge number?
I’m number 158! π
Dominic
Awesome Dominic!
To enter your OB number (#0158 is VERY respectable π ) you need to edit your profile. From the social bar at the top of overlandbound.com from the dropdown select Profile->Edit. Toward the bottom of the “profile” tab, you should see a field that says, “Overland Badge #”. Enter it there. It will then show up on your profile on the member map. Soon, it will show up in other areas as well (forums etc.) Does this make sense?
?cual es uestedes?
Muchas Gracias A Ustedes
?cual es ustedes?
