Midland ER310PRO Emergency Weather Radio
The Midland ER310PRO isn’t just a single powered emergency radio, it’s a multi-powered emergency radio with expanded battery capacity, USB-C charging, Bluetooth streaming, and integrated lighting and signaling tools.
The ER310PRO is more than an emergency radio with a hand crank. It’s a necessary piece of kit to help when the conditions become less than ideal.
Midland ER310PRO
Construction and Layout
The ER310PRO uses a molded housing with extra protection covering impact points. The antenna rotates and extends with moderate resistance and does not feel loose under adjustment. Button spacing allows operation without looking once familiar with the layout, and volume and tuning are separated, reducing accidental input changes during use.
The solar panel is integrated into the side of the unit and the crank arm folds into the rear handle assembly. The USB-C port is located on the handle end of the unit, reducing exposure when the radio is placed flat.
The overall form factor is larger than compact emergency radios due to the 10,000 mAh internal battery. That additional capacity defines both the size and the value of this model.
Power System
Internal Battery
The ER310PRO contains a 10,000 mAh lithium battery and Midland specifies over 200 hours of radio operation depending on volume level. Runtime will vary significantly between low-volume monitoring and maximum output use.
From a preparedness perspective, 10,000 mAh moves this device beyond short-term alert monitoring and into extended outage support. It also enables meaningful power bank use without sacrificing radio functionality immediately.
The battery is sealed and non-serviceable which means long-term ownership requires a maintenance charging schedule to avoid deep storage degradation.
USB-C Charging
Charging occurs via USB-C requiring 6–10 hours on standard 5V input and 3–4 hours when connected to a fast-charging power source. This aligns with modern power delivery standards and reduces dependency on legacy USB-A systems.
When charging external devices, the radio automatically switches into charge mode and this prioritizes power output stability.
In practical terms, the ER310PRO functions as a 10,000 mAh power bank that also happens to be an emergency radio. Midland notes that a full battery can charge an iPhone 14 up to three times but real-world output will vary by device efficiency and cable quality, but the capacity is substantial for a dual-purpose device.
Hand Crank Charging
Midland ER310PRO hand crank deployed
The internal dynamo allows mechanical charging. The manual states that one minute of cranking provides up to nine minutes of radio use. Crank systems should be evaluated as emergency sustainment tools, not primary recharge methods. Mechanical effort to electrical return is inherently limited.
In practical use, the crank allows preservation of alert monitoring during prolonged outages when battery reserves are critically low. It is not efficient enough to restore large battery capacity quickly.
Solar charging
The integrated solar panel provides supplemental charging. Midland specifies that one hour of optimal sunlight yields up to 45 minutes of radio use and solar output is highly dependent on angle, cloud cover, and placement.
The panel is suitable for passive topping while stationary, such as during extended daylight outages or while camped. It should not be relied upon as a primary recharge method in variable weather conditions.
NOAA Weather Alert function
The ER310PRO receives seven NOAA/NWS weather channels in the 162 MHz band and typical reception range is 25–50 miles depending on terrain and conditions. Weather alert mode activates an audible siren and flashing light when a broadcast alert is received and the alert can be manually acknowledged within the first minute.
Reception strength depends heavily on antenna extension and orientation. Fully extending and rotating the antenna is necessary for optimal clarity and in indoor use, placement near windows improves performance.
The Midland ER310PRO sits in an open field near the mountains.
AM/FM Radio performance
AM and FM tuning is digital, with frequency displayed on a backlit LCD. FM reception benefits from the telescoping antenna. AM performance is typical for a compact radio and adequate for regional broadcast monitoring.
Audio clarity remains intelligible at higher volume levels, though low-frequency response is limited by speaker size. This is consistent with emergency radios in this category.
Bluetooth integration
Bluetooth mode allows the device to function as a portable speaker. From a preparedness perspective, Bluetooth serves a practical purpose. Devices that are used regularly are more likely to remain charged. Incorporating daily use, such as campsite audio or household listening, increases the likelihood that the battery is maintained.
Battery consumption in Bluetooth mode will be higher than in low-volume radio monitoring. Users should account for this in outage planning.
Flashlight and signaling
The ER310PRO integrates a Cree LED flashlight with dim and bright modes. Bright mode is sufficient for short-range navigation and campsite movement. It does not replace a dedicated headlamp for hands-free work.
The SOS function emits the standard Morse pattern of three short, three long, three short flashes. The siren activates five seconds after SOS begins. This combination provides both visual and audible signaling capability in low-visibility conditions.
Ultrasonic dog whistle
The ultrasonic whistle is activated via the flashlight control with its intended purpose is to assist search and rescue teams in locating individuals. Its real-world effectiveness will vary by environment and proximity of trained canine teams. It should be viewed as a supplemental signaling feature rather than a primary rescue tool.
Durability and ownership considerations
The unit carries a three-year limited warranty in the United States. The internal battery is not user-replaceable and the long-term reliability depends on disciplined charging rotation. Storing lithium batteries fully depleted or unused for extended periods reduces lifespan. Incorporating the device into periodic use mitigates that risk.
Midland ER310PRO in the field.
Practical use cases
The ER310PRO is best suited for:
  • Vehicle emergency kits in wildfire or storm regions
  • Extended power outages in suburban or rural homes
  • Travel trailers and RVs
  • Overland vehicles operating outside cellular coverage
  • Household disaster preparedness kits
The combination of NOAA monitoring, power bank capacity, and multiple recharge inputs supports extended scenarios where both information and power are limited.
Limitations
The solar panel output is modest and dependent on ideal conditions. The hand crank is mechanically effective but inefficient as a primary recharge method. The internal battery cannot be replaced by the user. The speaker is sufficient for alerts and broadcast but not optimized for high-fidelity audio. These are tradeoffs inherent to compact emergency radios with integrated power systems.
Midland ER310PRO Assessment
The defining strength of the Midland ER310PRO is its battery capacity combined with modern USB-C charging and multiple recharge paths. The device functions as a long-duration alert monitor, a supplemental power bank, and a basic lighting tool within a single housing.
It is not a replacement for satellite communication, dedicated high-output solar systems, or standalone high-lumen lighting. It is a redundancy tool.
For users who prioritize layered preparedness (particularly in regions subject to wildfire, hurricane, tornado, or winter storm disruption) the ER310PRO represents a consolidated approach to alert monitoring and emergency power management.
Used regularly and maintained properly, it meaningfully increases preparedness resilience without adding unnecessary complexity.
All images by Midland
Overland Bound does not publish paid advertorials, and advertising does not influence our coverage. Our contributors maintain full editorial independence. If you purchase through affiliate links in this article, we may earn a small commission. This support helps sustain independent, community-driven reviews and resources.
