propane tanks
Lanlubber In Remembrance
I find that the 5 pound tanks work great for my wife and I. We can usually get two or three weekends out of a tank. I always have one small green one as a back up but havent needed it yet. I got mine given to me for free because it was out of date. Got it revalved and filled for about half price.
Why didn't you just trade it in for a full bottle at Wally world for $20
Wawa Skittletits
Local Expert East Region USA
Expedition Master I
So for travel or storage it's okay to let them lay on their side, HUH ?
Literally my next post...
Mine as well share the NFPA regulations...
  • You must transport propane cylinders upright. They cannot be laying on their sides. You must secure the cylinders in place -- usually with bungee cords -- to prevent them from falling over.
*** This one can be confusing since a tank designed to be on its side is considered upright ***
  • Propane cylinders must be as far from the driver as possible and must be isolated from the engine and exhaust system, which means putting them in the trunk if you're driving a conventional automobile. If you're driving a pick-up, the cylinders can be in the bed of the truck, and they can be transported in the same enclosure as the driver of a box truck or single-compartment van.
  • The total weight of the cylinders, including the propane they contain, cannot exceed 108 pounds. Since a filled appliance cylinder typically weighs 20 pounds, this requirement imposes a limit of five cylinders.
  • If the cylinders have safety caps to cover the valve opening, those caps must be in place. Only older cylinders lack these caps.
  • You can only transport propane in leak-proof containers --if you have an older cylinder you're not sure about, don't use it.
  • You must place the cylinders on a flat surface, such as the floor of the car, a truck bed or the bottom of the trunk.
2boverlanding
They only have the 20 pound tanks. I also like the compact size of the 5 and 7 pound tanks. When we use my wifes Kia to go camping they are easy to bring along. The only time i use the 20 pound tank is when the fire bans are on and we take the propane fire pit with us. Camping is not the same without a fire.
Buckaroo
<rant>
A fire pit starts and ends with a shovel
common misconception and it really bugs the fuck out of me.
fire pit, a pit to light a fire in.
a pit, a hole in the ground.
a fire below the ground is a firepit
a fire on the ground is a fire
a fire held above the ground is a fucking brazier.
</rant>
how the hell do you dig a hole, light the fire in the hole then fuel it with propane without making a fireworks display?
You are describing a fire lighthouse, not a pit
DrivingTacoLoco
I got one of these. I haven't mounted it yet (or filled it) but its a pretty good size.
I also got a large tank to 1lb tank hose
Consider getting 1lb Propane Tank Refill Adapter so you can refill all of those green ones. Sometimes they are more convenient. Especially if you use a Mr. Buddy heater
Patriot
<rant>
</rant>
:tearsofjoy::tearsofjoy::tearsofjoy: Rant On!!
2boverlanding
<rant>
</rant>
This was a nice rant
Truckee
You can also save a few bucks and have a bit more packing versatility by reusing the 1lb tanks and filling them at home. 5 1lb tanks are easier to stuff in tiny spaces than one bigger tank.
The fill adapters are about $20.00.
Yes.... but also noteworthy, the larger tanks are more resistant to freezing. I have an IR grill that doesn't do well with the 1lb tanks.
Buckaroo
I still need to see a pic of this propane "firepit", WTF is it?
it sounds like something Uncle Bob made in his yard
<------runs off to check Uncle Bob on youtube.
Patriot
Google is such a beautiful thing :wink: ....Propane Fire Pits or Fire Rings.
These are propane fire rings are which usually allowed to be used where there are wood campfire bans in National Parks and some State Parks. Generally considered less of a fire risk/hazard since they can be controlled/turned off.
I don’t own one and have never had to use one. Mystery solved.
Buckaroo
google is such a useless thing at times. "Let's split up and look for clues scoob".
so the firepit ( which it never was) has mysteriously turned into a "fire ring"
As you say...Mystery solved.
next quest, how to prevent folks naming stuff a firepit when it ain't?
PS. Thanx for the answer Patriot, I've had 2 sleepless nights already
Patriot
I guess it's better than nothing. Sure takes the fun out of it though and fully understandable considering all the careless people who start fires and fail to put them out properly even under good fire conditions.
Wallygator
I have that exact one you posted a pic of. Some might think it's stupid but having a fire during burn bans or in areas that don't allow fires has been invaluable. It's definitely not the same as sitting around a real fire but it's better than staring at the dirt and you can still make Smores or cook a hotdog over it. YMMV.
Patriot
I think it makes sense, especially using it during a fire ban. How easy does your pack up? Is it light weight?
Wallygator
It's not the smallest thing to pack especially considering you also have to bring the propane tank with you. It is light weight. As mentioned I only bring it when I can't have a real fire or if I'm lazy so I keep it in the original box which has held up surprisingly well after a year. The box is 19" L x 19"W x12" H. When the box wears out I will find a bag for it. I also use it from time to time at home on the deck. With the flick of a lighter you have a fire to hang out around. Then turn the knob and the fire is out.
Patriot
Thanks, great points. I may consider purchasing one for traveling across the US.
Top
