UPDATED: PREWITT RIDGE RD 2/17 -- CLOSED:Bixby/Coast Road 2/17
WheelMe
Soquel, California, USA
Patrick
Hung
W6AJR
Just appeared in the FCC database this morning. I put it in my signature below. It'll likely change soon because I applied for a vanity call sign.
Cool. Do you have a radio yet? I have an HT, but not sure how well it'll receive/transmit from inside the cab.
Sent from my Nexus 5X using Tapatalk
Reactions: JeepWave
2003DiscoII
Modesto, California, United States
Luis
Alvarado
The actual elbow connector. The hose was replaced to pass smog. But I had bought/supplied the shop the wrong connector.
Sent from my Nexus 9 using OB Talk mobile app
See if you can feel a leak with your hand. If not it’s fine and it might actually be your pcv valve clogged up causing the higher crank pressure
infennonlabs
A leak by the fresh inlet? Based on the parts the opening of the connector that sits in the valve cover is completely different. The one I have in now only has an opening the size of a nail vs the correct part being the size of my pinky.
What I should have installed:
https://www.morris4x4center.com/connector-53030591-m.html
What is installed:
https://www.morris4x4center.com/mopar-ccv-valve-fitting-assembly-53030492.html
2003DiscoII
Luis
Alvarado
What is installed:
I’m pretty sure a local parts store has them in stock if you still have time to swing by and switch it out
