Here in AZ we need lots of water when we go out, especially in the heat. Since it's a constant battle between room for water and room for gear, especially if our whole family of 5 is going out, I think we've gotten pretty good at conserving our water. One of the 'luxuries' that consume our water are showers. On one day or two day trips, it's no big deal for me to skip a proper cleaning, but on anything longer, it really makes a huge difference in how I feel if I can get clean every day.
I've come up with what I call "The 12oz Shower". I've told a few people about this here and there and thought I'd share it to the wider audience and also ask how you all stay clean out on the trail.
Supplies needed:
The real keys to this shower are the spray bottle and the chamois. The spray bottle helps effectively use the water, and the chamois helps with re-use of the water for the length of the "shower".
Preparation:
The process:
Q & A:
Is this as good as a shower at home?
No way, but it sure feels close.
How do you clean your hair?
I'm lucky in that I have a very short haircut. I typically just take the wet and slightly soapy chamois during the rinse step and rub it all over my hair. Those with long hair may have to skip the hair wash, or at least not wash hair every day.
Does this really only consume 12oz of water?
I'm guesstimating, but yeah, I put about 10oz of water in the basin, and usually only use up about 2oz from the spray bottle. YMMV, but the main idea is not that you only use 12oz of water, it's that you use significantly less than most other trail showers.
What about in winter?
What's that? I'm from Arizona. Ok, but seriously, I could see this process still working using warm/hot water in the basin and standing inside a pop-up or tent.
Now that you know how I keep clean, do you have any water-conscious shower tips of your own to share?
Supplies needed:
- General purpose spray bottle
- A chamois (or similar)
- Soap - any kind will do, liquid or bar.
- Wash basin - we use a collapsable one for easy storage.
Preparation:
- Make sure you have at least a few ounces of water left in your spray bottle. We use our spray bottle for washing dishes and things as well, so we just always keep it filled.
- Add the chamois and about 8-10oz of water to the wash basin. I typically put just enough in to get the chamois fully saturated with water.
- Have your clean clothes ready and take them along to wherever you are going to shower.
The process:
- Find a really nice location where you'll have an epic view during your shower. I like to find a secluded enough location where I can just strip down to full freedom. I look for a place where I can stand on something like a big rock surface so my feet won't get muddy or grimy as I shower. This process could be followed inside a shower tent as well.
- Using the spray bottle, mist your whole body to get it a little wet but not soaked - we are conserving water, don't forget!
- Take a little bit of soap in your hands and lather it up, then rub it around your body. Don't forget the important bits! I use just enough soap to keep me fresh, remember, the more soap you use, the more water you might need to rinse it off. Skip your feet, we'll get to those later.
- Take the saturated chamois and use it to wipe-rinse your body. I wipe it all over like I would a dry towel, except instead of drying my skin, it leaves it wet but now mostly soap free. Be careful to avoid squeezing water out of the chamois if you can avoid it.
- Squeeze-dry the chamois into the wash basin, get it as dry as you can, and capture as much of the greywater as you can - we will be using this again.
- Using the spray bottle, mist your whole body again
- Use the now-dry chamois to dry off your whole body, don't worry about your feet just yet, we're almost there!
- Now that you are mostly clean, feel free to put on some clothes again if you wish, but leave your socks and shoes off!
- Take a seat, or if you can balance like a flamingo, just step into the wash basin.
- Using the grey water and the chamois, give your feet a good cleaning inside the basin, recycling the grey water back into the basin as you go. Squeeze the chamois dry (back into the basin!) and use it to dry. I like to keep my socks and shoes right nearby so I can slip each cleaned and dried foot right into a clean sock and shoe to avoid stepping my nice clean feet back into the dirt.
- Squeeze out the chamois and dump out the grey water. You're done!
Q & A:
