Coyote Flats in a 2 x 4 4Runner?
JUSTIN DELAND
Want to plan a trip to Coyote Flats in Bishop at the end of June. I have a 2x4 2015 4runner with 285's and a 2.5" lift. Wanted some input if this trail is doable in my vehicle? From the research I've done, it looks like the majority of trails I've tackled thus far and have had no issues. I plan to go out there to camp and fish at Funnel Lake. unnamed (1).jpg
I would research the snowpack, even for the end of June. The only area I would be concerned about not having 4 wheel drive would be right after the initial switchbacks when you begin the climb from the valley. Lower air pressure will help here. I do think it is doable though. I have not seen any reports of anyone being up there this year so don't know what the winter weather has done to the trail. Have done that trip a couple of times and enjoy it every time. I have had good luck fishing in the lake too.
It's on my list of things to check before committing, especially after this record setting winter.
I appreciate the feed back. It looks like a beautiful place to drive some trails, camp and huck some flys.
Coyote Creek (leading to Coyote Flats) is one of my very favorite trails. Here are a few shots from my drive there on Thanksgiving weekend (literally the day before this year's snowfall began!) Again, not sure what the conditions are like up there this year, but I think your rig should be fine with some driving skill and a little momentum. The creek crossing will probably be deep this year!
15171066_925323781686_5733551790993312508_n.jpg 15181687_925318711846_4131663116375338372_n.jpg
Does it have a locking rear diff? I used to go all sorts of places in my 2wd 318v8 Dodge Ram, mechanical locking rear diff, because my wife wouldn't let me take our pristine D1 Discovery... :-P
Even w/ the 'construction worker' tires, that thing was a mountain goat! You'd be surprised where it'll go w/ some good driving... and that rear diff.
I'm following too! :-P (I'm a jeep guy, though, so don't tell anyone)
Reactions: JUSTIN DELAND
I'm also very interested in how you do. Maybe check out Youtube if you haven't already. Best of luck!
Youtube is my best friend when it comes to scoping out trails to judge if I can make it or not.
Been checking the hashtags on instagram too to see updated conditions, although those are few and far between for #coyoteflats ect.. There was one recent expedition that just went through there and seemed to run into snow, but they pinned it and made it.
If I can't find a 4x4 to come with and be the support vehicle, I'm going to delay the trip and run up to Prewitt Ridge in Big Sur.
Reactions: LostInSocal
I do the same thing, youtube is awesome for that. Hope it clears out for ya, I see your just a few days away from your target date. I'll be following as well!
Hopefully you find someone to tag along with you. I've got a 4x4 but nothing at the moment in terms of recovery gear. Keep the post updated when you figure out a new date (if you have to delay). I'm right up the 57 from you in Chino Hills.
Just got back from Coyote Flat. I would not attempt it in a 2x4. At least not this year. There were some steep rocky sections which might not be passable for you. I was in 4X4 the whole time, and 4X4-low in several spots. To LostInSocal, 4X4 is really all you need. You shouldn't need recovery gear of any kind. But you should definitely have a flat tire repair kit, there are sharp rocks everywhere. There was no snow, nor muddy sections. Just a lot of rocks. My truck is fairly stock, no lift, and I'm running skinny 32's. I had no problems.
Thank you for the up date on the trail!
Are the rocks the type that will do side wall damage? Rock rips are usually not repairable, at least in my past experiences.
If you are careful, you should be fine. We didn't have any problems. Most of the sharp rocks are avoidable if you look out for them and go slow. There were a few areas where the sidewalls did catch some sharp rocks, but my tires held up (BFG KO2). The Eastern Sierras have a lot of sharp granite rocks, but if you have good tires, I think you will be okay. I was running about 20PSI, my father in law was running 25.
This was probably the most difficult part of the trail. The rocks aren't too sharp here, but it's tougher than the photo can show.
A lot of it depends on the tires you run. Outside magazine ran an article on Coyote Flat last year. They took a Jeep cute-ute with stock tires. It got a ton of flats but the 4Runner in the group didn't get any. For what it's worth, I had BFG KO2's and my father in law ran Falcon WildPeaks. I ran about 20 PSi and he ran about 30. We were both fine. But tires make a difference.
