Water crossing fail
Dusther210
World Traveler III
5,483
Oakland, Bergen County, New Jersey, United States
Dustin
Helms
KD2UNH
USAF
Well, he didn't get stuck or hydrolocked...
Thankfully we didn’t got out. The engine had shut off and it felt like it took forever to start (even though in the video you see it didn’t take too long). We were able to get out but the engine was never the same and it wasn’t long after that trip the engine quit as a result.
At the end of the longer video my wife wanted to drive and we got really stuck
Dusther210
World Traveler III
5,483
Dustin
Helms
KD2UNH
USAF
Doesn't show what happened.....
Not a fan of clickbait videos.
It’s not a clickbait video as much it is a trailer. The short version has a link to the longer video that most people found boring.
The video is also old and at the time I made it there was a popular trend of making a video with that song and “to be continued” with the video freezing at the climax.
Clickbait is when the thumbnail or title of the video says something hyperbolic like “craziest adventure to the most remote place on earth. I almost died” but the contents of the video are not crazy, is not an adventure, the location is not remote and the host most surely did not almost die. I hate clickbait as well.
CR-Venturer
Ardrossan, AB, Canada
Jas
Spr
You probably already know this by now, but two things:
Go in slow, come out fast when facing big bog holes like that. Good idea to check the depth first, especially if you don't have a sealed snorkel setup. Keep a bow wave in front of the grille to keep the water mostly away from the engine and prevent the big flood over the hood.
If your engine ever shuts off while in water/after a big splash like this, DO NOT try to start it again. Get yourself out of the hole onto dry land, then pull all the spark plugs and crank the engine with the plug holes open. This will usually blast out all the water from the cylinders and prevent damage to the engine. I drowned the CR-V in an insane, car swallowing pit that was small in diameter but DEEP. I got a buddy to pull me out backwards, then did the procedure I described. The next day, it didn't even have a check engine light and after an oil change, the car ran perfectly fine until a snapped timing belt unrelated to the swamping ended its run.
Reactions: Dusther210
Dusther210
World Traveler III
5,483
Dustin
Helms
KD2UNH
USAF
This is very sound advice, thank you for sharing.
I had learned proper fording technique shortly after this “event”
Actually I think I learned it from an Overland Bound YouTube video, if I remember correctly.
Reactions: CR-Venturer
lolzhax
Roseville, CA, USA
Eric
Walley
The clickbait was the thread title and a video that didn't show a result. So while your organic video may not be, the context of how you presented your video to us on the forum was clickbait.
Thank you for following up with a better link. Sorry to hear about the motor.
