Howdy from Texas
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
Hopefully doing this right building out my Rig a 2001 Yukon XL 4x4 that I have had 17yrs started with 6 1/2" BDS Suspension lift & 35" Nitto Ridge Grapplers and just dropped in new crate 5.3L replacement motor last week
Have done lots of state park tent camping, some hunting and lots of fishing but never what i would classify as full vehicle dependent overlanding.
Houston Area
Looking to learn a lot on getting my rig built right the first time and sharing what little bit I know
Roots66
SouthWest Region Member Rep Texas
Georgetown, TX, USA
Roots
USAF / FEMA CERT
Welcome from just west of you in Georgetown. If you are ever in the area, we have a monthly meet up and also do some day trips, as well as overnighters.
Reactions: TxasYukonXL
Executive Director
Supporter
Houston Area
Welcome to Overland Bound
I do have one piece of advice for you about the lift. Hopefully the shop that installed the lift also upgraded the CV axles, this is very important with this vehicle. DM to follow.
Overland Bound Meetups
Overland Trip Planning
OVERLAND BOUND COMMUNITY
The closest Member Representative is @Prerunner1982
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
Did not upgrade the CV axles but will put on my list and thanks for the advice exactly why I joined Overland Bound...
Reactions: Kent R
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
Thanks Roots66 may take you up on that once i get passed this 500mile new motor break-in period and can open her up for some distance travel
TxJeeper75
Adventure
San Antonio, TX, USA
Heiman
KI5LHN
Welcome from San Antonio. I just want to say I second the suggestion from Kent R about upgrading the cv axles. I had an 05 Sierra with a 6 in. lift, and I learned real quick that a lot of stress is put on the joints at the new angle. I only found this out after mine had a catastrophic failure. Heard a clunk one day while on the highway. Pulled over and saw the boot was torn near the hub. Called for a tow, but they were going to be an hour, with a $250 cost. I wasn't too far from home, so I tried to limp it back, but 3 blocks from home, the tire fell off. Luckily I was only going 10mph when it happened. I skidded it the rest of the way. Not sure what failed first, the cv or the hub assembly, but it was after doing some research that I learned the cv was prone to failure after lifting the vehicle.
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
Thanks for the info couple of questions What type of lift did you have on that truck? What did you replace your cv axles with?
TxJeeper75
Adventure
Heiman
KI5LHN
The lift was Tuff Country. As for the axle, I was already planning on selling the truck, so I just found a replacement. There are options out there for beefier CVs.
Maybe someone else on here will have more info for that. If I had the money, I would go with these.
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
The lift was Tuff Country. As for the axle, I was already planning on selling the truck, so I just found a replacement. There are options out there for beefier CVs. You just have to do some research. If I had the money, I would go with these.
Thanks again... those are some nice CV axles but considering I am still breaking in my new motor think I will get a spare stock set and keep in truck with tools for now until the budget says different
Wish i had photo of original angles to compare to current below which I don’t think are too bad although i know that is different from strength
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
Mike,
Did some homework and wheeling this weekend in Sam Houston National Forest solo and started thinking about how I would not want to get caught in the middle of nowhere ... so ordered these CV Axels from O’Reilly looks a more robust than stock also will add some tire rod sleeves as i don’t plan on doing any Rock Crawling but hoping that keeps me steady and on the road for some time while i am discovering what kind of overlanding i plan on doing
Will stall these and keep my stock as spares in the truck with tools to do the swap on the trail if necessary
Thanks again for the advice hope you are enjoying the Jeep now believe i have a few years in Yukon XL before i max out its capabilities
Reactions: TxJeeper75
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
Engine Break-In is officially done a couple of day trips to the Sam Houston National Forest no under my belt..sharing a few pics and some notes made on pdf map i was using to find my way around hopefully useful to Newbies like me likely old info for you wheeling seniors
Plan on making my way back in a couple of weeks with my kayak and may do an overnight once i knock some dust off my tent after digging it out of the garage
TxJeeper75
Adventure
Heiman
KI5LHN
Mike,
Those look like they'll do the job. Glad to see you were able to find something more affordable. They should last you a good while. Having a good time gearing up the Jeep. Recently installed a gas can mount and a mount for my shower tank. Waiting on a rear window from Smittybilt so I can work on the fridge slide and drawers.
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
View attachment 170148View attachment 170149
TxasYukonXL
Adventure
Houston, TX, USA
Henry
Jackson Jr
Setup looks Great one of the best thng about Jeeps is that so much is available aftermarket... Do you have to pump the handle on the shower to build pressure or do you have a battery operated pump? How long are you out when you go on a walk about?
Picked up the battery operated shower system below to rinse off after kayaking having a mount would save lots of hassle as i need to fill water bucket for source
Spending more time doing day trips to the Sam Houston National Forest starting to figure out what i need to carry every trip and nice to haves.
David H
NorthWest Region Member Rep Southern ID
Boise, ID, 83713 USA
David
Hopkins
WRKQ684
Houston Area
Henry,
Idaho sends you a warm welcome to Overland Bound.
