When I bought this mog it had only 4350 mi (7000 km) on the clock. The engine was barely broken in!
The plan was to build an overland vehicle that would fit into a cargo container to be shipped safely anywhere in the world. The construction was quite a challenge and the result is impressive. The camper unit can be mounted and dismounted by one person using an electric winch without many extra tools and so the Unimog + the camper unit fit together in a 40 ft. high cube container, as an alternative to RoRo shipping!
An additional advantage is that when you are not traveling for a while, the original cargo bed can easily be remounted and the Unimog serves as a truck. The camper unit becomes a tiny house...
Now my priorities lie elsewhere and I have decided to put it up for sale.
Unimog U1350LM
The U1350 LM was a special order for the Belgian army and is actually a U1550L whose engine power has been reduced to 136 hp, something that can easily be increased again to 215 hp or more.
Some important improvements over a U1300L are the modern cab with improved sound insulation, higher payload, stronger axles, the heavier UG65 transmission and the turbocharged engine with intercooler.
Technical specs
- Unimog U 1350 LM (437.110 / 437.111 / U1550)
- Year of construction: 1996
- Mileage: 6982 mi (11236 km)
- Type designation: wdb4371111w
- Vehicle weight (without camper unit / cargo bed): 3950 kg (8700 lb)
- Maximum gross vehicle weight / GVWR: 8500 kg (18700 lb) [can be reduced to 7500 kg for C1 driving license]
- Gross train weight / GTW (vehicle + trailer): 24500 kg (54000 lb)
- Engine OM 366 LA turbo intercooler, Diesel Euro 2
- Engine capacity 5958 cm3
- High air intake
- 24 volt system
- Reinforced chassis and axles
- Heavy duty gearbox UG 365 (8 speed)
- Drive can be switched while driving: 2x4, 4x4 and differential lock on both axles
- New type of interior and lighting
- Wheelbase 325 cm (128")
- Tires: Uniroyal 12.5 x R20 - front and rear 90% profile
- NATO hitch: suitable for a trailer of max. 10000 kg (22000 lb)
- The rear bumper can be raised when driving rough terrain
- Cabin has room for 3 people: driver + two-seater sofa
Camper unit
- Inner dimensions: Headroom 200.5 cm, floor (LxW) 324x214 cm, total inside length (from rear wall to front wall) 359 cm, alcove depth 100 cm, total inside length 459 cm
- Weight: 1400 kg (3090 lb)
- Interior: no interior has been fitted
- Windows: PaBST - Air Tec: 2 @ 100x50 cm, 1 @ 30x20 cm, 1 @ 30x70 cm (the latter has not yet been installed). All windows include fine mesh (black) mosquito netting and blinds.
- Door: insulated, with stainless steel three-point locking system. Door opening dimensions (WxH) 57.5x179.5 cm
- Insulation: walls 40mm PIR, floor 20mm HD XPS
- Floor: oak floorboards 10 mm, jointed with bostik marine sealant
Cargo bed
- The original Unimog cargo bed has been modified for the demounting system.
- Tool box (LxWxH 220x60x80 cm)
- Weight: 850 kg (1875 lb)
Vehicle dimensions
- Truck with cargo bed mounted: LxWxH = 555x230x254 cm (218.5x90.5x100")
- Truck with camper unit mounted: LxWxH = 600x230x335 cm (236x90.5x132")
Accessories
- Original Unimog on-board tools
- Tools belonging to the demounting system
- Bed lift (Project2000 unit )
- 2 x household battery Brega Calcium-Calcium 12v, 100 Ah + Cyrix CT 230 Amp
- 2 x wheel chock
- Fire extinguisher
- Spare wheel: Uniroyal 12.5 x R20 - 100% profile
- Tow bar
- Air hose + tire inflation pump/pressure gauge
- 12 tons hydraulic jack
- pioneer shovel
- 2 x jerry can 20 liters + holder
- 4 x snow chain, Mercedes Benz
Price (Unimog + Camper unit + Cargo bed + Accessories)
- 68,000 euros.
For more photos and videos have a look at: https://www.globaltravelconcept.com
Unimog U1350LM
Technical specs
- High air intake
- 24 volt system
Camper unit
Cargo bed
Vehicle dimensions
Accessories
- 2 x wheel chock
- Fire extinguisher
- Tow bar
- pioneer shovel
- 68,000 euros.
