SOLD!c Bad A Off Road Trailer (BORT) for sale -Custom built. Built to match 2013 Jeep Wrangler Rubicon (listed in Rigs) that is for sale also. (facebook.com/Photos4Aidan/posts/pfbid0efERFBveu1j3gygTTmtD4JJ5U1uwCaHTCrvtkzg3UyH4XMoFCFSJkBVMLv5yxFDJl)
Asking $9,000 OBO (Jeep and trailer combo — $30,000) Can buy and fly...all ready for your trip!
Clean title in hand and ready to negotiate.
11’ x 6’ Custom built Offroad trailer, Max Coupler hitch with 7 way trailer plug, electric brakes, 3500# axle on leaf springs, riding on 33x12.5/R15 (General Grabber AT2)—15x10 rims.
-TOAD charging line with plug in and battery electrical/charging system.
-TuffStuff 2.5 person RTT on (manual) gas spring telescoping mounts with vestibule and 6x8 awning over kitchen area.
-Portable hot water heater and shower, with pump and 25 gallon water tank.
-Pull out rear drawer with drop down gate and top open lid.
-Pull Out Kitchen w/ Coleman grill/stove,
-LED spot lighting upper and underneath with remotes. LED lighting on interior of tent with remote
BUILD/DIMENSIONS
11 foot (3 foot is the hitch) by 6 foot
Tire Width 78” on Jeep track
3500# axle- Hubface 61.” Spring Center 46”. Overslung
Rims/Tires- 33x12.5/R15 (General Grabber AT2)—15x10” -44cm offset, 5 on 5.
TRAILER PARTS
Original Trailer 4’x4’ DOT Sign Hauler w/ 2”x4” I channel
Max Coupler Hitch with BOLT locks (matches vehicle key)
Leveling stands
Tuff Stuff Overland Rooftop Camping Tent with Annex Room- Black Driving Cover
ALPS Mountaineering Velocity Air Bed with rechargeable inflator
TuffStuff 6.5’ x 8’ awning
3600 Series 500 LB Full Extension Lock In/Out Drawer Slide (60inch) for kitchen
Jack Mounting Pipe x3
Square 3 ton trailer jack w/ flat and wheeled bases
Monstaliner Sans Panties Paint (Commando Green)
10" Nev-R-Adjust Electric Brake Assembly for 3.5K Axles
Rollout tray rear.
Removable/storable Table
Fast knuckle mounts with shovel and axe
Spare replaceable parts
Water
Eccotemp L5 Portable tankless shower/water heater
Custom Roto-Molding L4A RV Fresh Water Tank 25 gallon
Flojet 03526-144A Triplex Diaphragm Automatic Water System Pump, 2.9 GPM 50 PSI, 12 volt DC
Water from tank, water utilities, or pumped from natural water body
Fresh water hose
detachable kitchen water hose and misting setup
Popup shower stall
Kitchen Propane
Coleman Grill/Stove in pullout Chuck Kitchen
20# propane tank
Coleman 8 Ft. x 2 Propane Hoses for stove and hot water heater
Stansport Propane Appliance to Distribution Post (5-Feet)
Electrical
12 volt and 110 plugs and charging setup
Power line for TOAD charging-2 gauge
Universal 2-4 AWG 175A Battery Connect Quick Connector Plug
Blue Sea Systems Push Button Reset Only Quick Connect 30A Circuit Breaker
LED Rock Light Kit on remotes
Driver Battery Quick Connect Plug Kit Recovery Winch Trailer 350 amps
GOAL ZERO Yeti 125AH BATTERY UPGRADE
Cobra CPI-A20 AC Power Inverter Remote
Cobra CPI 1575 1500 Watt 12 Volt DC to 120 Volt AC Power Inverter
Battery Tender (022-0186G-DL-WH) 12V 5 Amp Battery Charger
Mictuning 12V/24V 6 Gang LED Switch Panel Slim Touch Control Panel
2 LED Spot lights on Remote
Oval Dual Revolution Red/Reverse Light Combo 12 LED STT Light
2 external lighter sockets
BUILD/DIMENSIONS
TRAILER PARTS
Leveling stands
Rollout tray rear.
Water
Fresh water hose
Popup shower stall
Kitchen Propane
20# propane tank
Electrical
