Hello folks,
As a member of GLASS (GreenLaning Assosiation UK) I do drive by the rules of conduct they provide.
Which simple means, RESPECT to nature and other Participants that enjoy the same part of nature as you do.
Here are these rules by GLASS
Use only rights of way with known, proven or provable vehicular rights. If challenged, discuss; if not resolved, then leave as requested until status is rechecked.
Keep to the defined track. Detour only to pass immovable obstructions. Report any obstructions (including low branches) to the highway authority and the local GLASS Area Representative. Be critical of your own abilities and equipment when assessing an obstruction; it is your right to abate a non-lawful obstruction, but do not commit yourself to a bigger task than you are equipped for.
If the route is not obvious on the ground, ask locally, or check on the maps held at the highway authority offices or consult the local GLASS Area Representative.
Travel at a quiet and unobtrusive pace and as slowly as practicable; we recommend a maximum of 12 mph when in a 4x4 and on an Unsurfaced Right of Way (URoW). Ensure your vehicle is fully road-legal, URoW are subject to the same laws as surfaced roads.
When travelling in groups keep to a small number, four or less in sensitive areas, in other areas up to six vehicles MAY be acceptable. Guidance should be sought from the relevant GLASS Area Representative. Weather and ground conditions should also be taken into account. On routes in good condition, split larger parties up and either use a different route or allow a good interval, at least 30 minutes, to elapse before following. With adverse weather and/or poor ground conditions avoid committing a second group to follow the same route.
Do not travel on URoW when they risk being affected beyond a point of natural recovery once the weather improves. If need be, walk some or the entire route first to determine its suitability. Do not use URoW that maybe damaged by the wheel pressure applied by your vehicle.
Avoid damage to trees, hedgerows and boundaries. Some roads carry vehicular rights but are physically too narrow for 4x4s.
Do not practice recovery techniques on any URoW. Use a winch only with extreme caution, and use only the correct equipment and techniques.
Be courteous to other road users - pull over and stop your vehicle for walkers, but pull over, stop your vehicle and switch off the engine for passing horses. Thank those who move over for you.
After consultations with Country Landowners Association and National Farmers Union HQ’s, “best practice” dictates that gates if they were found to be secured in an open position should be left open and those which are found shut or swinging should be shut behind you; the landowner might appreciate being told about a gate insecurely propped open if you see them.
Keep dogs and children under supervision. Watch out for injured or trapped animals, and report all suspicious events to the landholder.
Guard against all risks of fire. Take your litter home and that left by others if you see it, wherever practicable. Plastic bags can suffocate livestock if swallowed.
Help to keep all water clean. Remember that wildlife faces many threats and URoW are valuable habitats, take special care in spring and early summer. Follow the Country Code, it is for your guidance only.
Be considerate of group sizes at meeting points or food stops.
Driver's guide
This document is a draft item to give the feel of what may appear here.
Then it is extended by the rules of conduct by the Tread Lightly organisation.
Tread Lightly Website
Travel with minimum impact
Respect the environment and the rights of others
Educate yourself, plan and prepare before you go
Discover the countryside responsibly
Greetings from Robert
Driver's guide
- Keep to the defined track. Detour only to pass immovable obstructions.
- Be critical of your own driving ability and equipment when assessing an obstruction; it is your right to abate a non-lawful obstruction, but do not commit yourself to a bigger task than you are equipped for.
- When travelling in groups, keep to a small number – four or less. Split larger parties up and either use a different route or allow a good interval to elapse before following.
- Use a winch only with extreme caution and if circumstances demand it. Ensure you use only the correct equipment and techniques.
- Avoid mud. Where the surface may easily be damaged, be very gentle on the throttle to avoid wheel spin.
- Never drive on moors and marshland.
- Practice minimum impact driving at all times.
- Practice driving as quietly as you can.
- Be considerate of other users at all times.
- If your right to travel is challenged, discuss; if not resolved, then leave as requested until status is rechecked.
- Travel at a quiet and unobtrusive pace and as slowly as practicable; we recommend a maximum speed of 12mph when driving on an unsealed Right of Way.
- Avoid damage to trees, hedgerows and boundaries. Some roads carry vehicular rights but may be too narrow for your vehicle.
- Be courteous to other road users – pull over and stop your vehicle for walkers, cyclists and horse riders, switch off your engine for the latter.
- Thank people that move over to let you pass.
- Watch out for injured or trapped animals, and report all suspicious events to the landowner.
- Ensure you have up to date maps.
- Before setting out to remote area’s check the weather forecast and let someone else know where you are going and when you are likely to return.
- Ensure you have adequate fuel for the journey and check all levels before settling out.
- Never enter private property without permission of the land owner.
- If in any doubt walk a route prior to driving it, to determine its ability to sustain traffic, if in any doubt turn back.
- Ensure your vehicle is maintained to a high order and up to the task.
- Avoid travelling alone.
- Maintain a reasonable distance between vehicles.
- Wildlife faces many threats and many Unsealed Rights of Way are valuable habitats, take care at all times and be particularly watchful in spring and summer. Avoid area’s of special scientific interest
- Study the Country Code and follow it at all times.
- Do not travel on any Unsealed Right of Way when they risk being affected beyond a point of natural recovery once the weather improves.
- Do not use any Unsealed Right of Way that may be damaged by the wheel pressure applied by your vehicle.
- Gates that are secured open should be left so, all gates that are found closed or swinging open should be closed behind you.
- Travel within existing wheel tracks, never create new ones. Where several exist search out the original route.
- Take your litter home with you.
- Carry a bin bag and collect any litter you may see along the way.
- Do not scare livestock or wildlife.
- Do all you can to avoid polluting any water ways.
- Use only rights of way with known, proven or provable vehicular rights.
- Report any obstructions to a Rights of Way to the highways authority and to Tread Lightly.
- If the route is not obvious on the ground, ask locally, or check on the maps held at the highways authority offices, or consult with Tread Lightly representatives.
- Ensure your vehicle is fully road legal. Rights of Way are subject to the same laws as normal sealed roads.
- Do not practice recovery techniques on any public Right of Way.
- Keep children and dogs under supervision.
- Guard against all risks of fire.
- Clean down front and rear vehicle lights and number plate before returning to the highway.
- Respect the environment and all other users. Common sense and common courtesy will ensure a future for our lanes.
