I have 20' of 3/8th G80 chain to use with the Hi Lift recovery kit, it weighs 30lbs.Good. How long is your chain and how much does that beast weigh?
Thank you for sharing those articles, @smlobx. No argument from me that there are better tools than chain, but your first post suggested that it was never OK to use chains and that's not been my experience at all, but these articles have helped clarify that a bit. The criticisms of chain (especially when compared to other options like synthetic straps) are totally fair, but there's lots of times when a chain is all you have, and there's nothing wrong with using it that I can see from the articles. The above quote is far more consistent with my experience. The problems both articles identified are not unique to chain; in quick summary both articles talked about weight, making sure the chain was rated for the load, connecting chain securely, and their inelasticity -- all good factors to know about, but they apply to lots of other types of recovery gear as well. My takeaway is that there's nothing inherently wrong with using chain in a recovery if the appropriate chain, properly secured, is used by someone who knows what they are doing, which is true of all recovery gear........
Make no mistake, a chain has its place. Chain's resistance to abrasion means it can be ideal for dragging objects like rocks or logs out of the trail. These jobs could quickly destroy a strap or rope and don't (or shouldn't) normally cause shock-loads on the chain. Chain's lack of elasticity also makes it better for jobs like using a Hi-Lift Jack to winch yourself out of a jam.
I am not saying that a chain can never be used for recovery. I "AM" saying it is a poor choice for the job and far less safe than using properly rated recovery gear. In other words, using it is not even close to being a "Best-Practice" and can be quite a dangerous practice.
Now, hopefully, you know a little more of why a chain is a very poor and dangerous choice for bogged vehicle recovery.
Pathfinder II
Traveler II
================================================================================================Below is a really good review on Snatch Strap safety... and shows why I don’t snatch.
Pathfinder II
Great wisdom here.================================================================================================
Thanks for posting this video. I had seen it once before, a long time ago. It is a great reminder on the dangers and possibilities of when a recovery might go bad. Between Madd Matts and Ronnie Dahls videos, you see the respect needed (caution) when a H/D recovery is involved.
Videos like this should be shown in all recovery classes taught, along with individuals doing it on their own, before hitting the trails. This teaches prudent behavior, not to scare prospective off-roaders, but to educate. There bye evaluating how your gear gear will react if it goes 'pear shaped' should be a number one thought before you start attaching the recovery gear.
I have watched all the recovery videos I have come across, just to educate myself on techniques to properly self recover, and when helping other's. It never hurts to be humble, The adage,,,,,,,,,'a wise man knows there is always more to learn' is a good attitude to have.
Traveler II
.........................................................................................................................................................................................................................That video was done to intentionally fail.
As with all recoveries, regardless of the material used there is always a chance of failure. In the video posted above the strap was attached to a massive tree to induce strap failure. The results would have been much more severe if a chain had been used....
Quality of stuff is always an issue these days, no disagreement there. I'm shocked at the price-for-quality equation with some kit that I've seen. But my main point isn't about the quality you find at a hardware store -- it's the fact that every town has a place selling chain, but not every town has a place selling purpose built 4x4 recovery gear. Industrial clients still use a lot of chain -- truckers, heavy equipment operators, etc. -- especially in North American places that a lot of us over landers like to go where forestry or mining are the big industries, and because of OSHA requirements, this stuff is almost always labelled and rated. I do agree that the local Home Depot may not be the place to get the kind of product we're talking about, though.^^^
Thanks for your comments and perhaps my initial comment was a bit harsh but there are a lot of newly minted overlanders that visit this forum and deciding what to buy to extract a stuck vehicle a chain would be the last choice. I just wanted to make that clear.
I’ll have to disagree with your statement about easily being able to go into your local hardware store to pick up a chain for removing a vehicle. Most hardware stores just have Chinese junk nowadays and may not be properly labeled if at all.
When you make the decision to get something buy the right tool for the job.
Pathfinder II
Yes I know they were meant to intentionally fail... that being said... did you see how much power was behind the failed strap... with a few slices and weakened points, there was still enough stored energy to kill some one.. a proper chain won’t fail... hence the 5/16” chain he used as a safety tied to the tree as well. He went over that very clearly in his video as he also explains a strap/rope is only good for towing regardless weather it’s a kinetic or not... the end of the video shows the test with failed kenteic straps as well designed for recovering semi trucks... again... 30 years in the recovery business and not one chain has failed me... EVER... and I can’t tell you how many times a brand new unused strap/rope has failed me... so many that they stay on the shelf now...That video was done to intentionally fail.
Pathfinder II
