Influencer III
Mine does and has the subwoofer mounted in the floor, but the power to the cigarette lighter adapter goes off when you turn the engine off. I remember reading somewhere you can flip a fuse in the fuse box to change this, but i can't find where i read what fuse it is.So your 2017 doesn't have power in the rear port when the Jeep is powered off? I know my 2014 Sahara JKU does have power all the time. I have the side mounted subwoofer with the cigarette lighter connector build into that panel. I wonder if it's wired differently than no sub?
Thanks! Using that information I was able to pull up a fuse box diagram and picture. Going to have to play around with this on my day off!!(M7) is a 2 position fuse. One position makes the outlet hot all the time. The second position makes the outlet hot when the key is in ACC or RUN.
