2021 TURTLEBACK EXPEDITION SERIES T3 UPGRADED BUILD PACKAGE
Hello All,
A follow member on offerup suggested I give Overland Bound a try. He has a trailer already and found my posting. Planning a family change with our house and need to part ways with the trailer, sad to see it go but hoping it will go on to a good place.
I have owned the trailer since April of 2022. Used it most frequently for day trips to local beaches with light gravel trail riding. Been on 10 or so weekend trips with pretty basic gravel road and BLM trip off-roading. Very limited difficult off-road use so the trailer is basically in perfect condition. No dents, scraps or rock chips.
Thank you for the sticky on how to post, hoping I followed forum etiquette.
Only thing not coming with it is the fridge.
Price: $28,000
Contact Information:
Shawn - 425-785-8977
No issues and the trailer is in like new condition, always garaged.
Has the low roof rack so the trailer fits under a standard garage door and sits at 80.5"-81" off the ground with the current Alucab RTT.
Alucab Gen 3 Roof top tent with power.
23Zero 180 Degree Awning
Electronics and Battery Systems:
- Lithium Dual Victron Batteries
- Alucab Gen 3 Rooftop Tent
- 2000 WATT PURE SINE WAVE INVERTER WITH BLUE SEA 150 AMP BREAKER
- ZAMP 90WATT PORTABLE PANEL PRODUCES 90WATT AT 5AMPS, WEATHER RESISTANT, 5 STAGE, 10AMP CHARGE CONTROLLER, ALLIGATOR CLAMP ADAPTER INCLUDED.
- ADDITIONAL CHARGE PORT (DRV REAR KITCHEN, PASSENGER REAR KITCHEN, MAIN STORAGE COMPARTMENT)
- C-SERIES RGB MULTI-COLOR MULTI-USE LED 6-LIGHT SYSTEM
- 6 x KC C-Series RGB LED Rock Light Pods
- EXPEDITION RIGID REVERSE LIGHT KIT
- 4 EXTERIOR FLOOD LIGHTS, 4 STORAGE BOX LIGHTS, 1 MAIN STORAGE AREA LIGHT, 1 NOSE BOX LIGHT, 1 UTILITY AREA LIGHT, 1 CONTROL PANEL LIGHT, 3 UNDERCARRIAGE GREEN "TURTLE" CONVENIENCE LIGHTS
- 7-PIN TRAILER CONNECTION: INCLUDES CHARGE LINE, BRAKE CONTROLLER LINE, RUNNING LIGHTS, SIGNAL LIGHTS, AND REVERSE LIGHTS
TURTLEBACK SIGNATURE SUSPENSION:
- ICON VEHICLE DYNAMICS REMOTE RESERVOIR SHOCKS, CUSTOM PROGRESSIVE SPRINGS
- EXPEDITION PREMIUM TOPO GRAPHICS
- DUAL / Ark Drop Down Corner Trailer Stabilizer Jacks
- 16 INCH STEEL WHEELS WITH ALL-TERRAIN 285/75R16 TIRES
- SWING OUT TAILGATE WITH FLIP-DOWN TABLE, SPARE TIRE MOUNT, AND ROTOPAX MOUNT. MOUNTED ON IDLER HUB ASSEMBLY FOR AXLE SPARE.
EXPEDITION SLIDE-OUT KITCHEN:
- INCLUDES PARTNER STEEL STAINLESS STOVE WITH DUAL 10,000 BTU 18" BURNERS, LID, AND ADJUSTABLE WIND GUARDS, DUAL PRESSURE PROPANE SYSTEM, DOMETIC DEEP WELL STAINLESS STEEL SINK AND FAUCET WITH TEMPERED GLASS
- INTERIOR SIDEBOX MOUNTED CONTROL PANEL WITH BLUE SEA 8 CIRCUIT BREAKER PANEL, BATTERY POWER DISCONNECT, 2.1A USB CHARGE PORT, 12V SOCKET, OLED VOLTMETER, AND WATER HEATER SWITCH.
- DUAL STAINLESS STEEL FOLD DOWN PREP TABLES
- 42 GALLON, FOOD GRADE, BPA FREE, WATER TANK WITH EXTERNAL, LOCKABLE FILL DOOR (VENTED)
- 12V ON DEMAND WATER PUMP 3 GPM, 55 PSI, SELF PRIMING
- Dometic 6 GALLON DIRECT SPARK IGNITION WATER HEATER
- ACCESSORY 5LB PROPANE TANK AND MOUNTING BRACKET
- TURTLEBACK CUSTOM FRIDGE SLIDE
Shower Enclosure:
- 23Zero SHOWER ENCLOSURE
- LOCKABLE EXTERIOR USE SHOWER WITH DEDICATED VALVE CONTROL, 5' PVC HOSE, AND SHOWERHEAD
- 11 LB PANCAKE TYPE TANK FOR PRIMARY ON-BOARD SYSTEMS (DRIVER'S SIDE)
Hello All,
Price: $28,000
Shower Enclosure:
