Pop up camper
VST
Hey guys not sure this is the right section to post but I’m doing some research in hopefully getting a pop up camper for my Silverado. I was wondering if you guys had any expierence with any of these. The first one I was looking at was the four wheel campers raven model because I have a 5’9 bed or any pop up camper similar. I’ve also been looking into go fast camper, vagabond camper, and the new company overland camper. The benefit to the four wheel camper is that it’s pretty much setup and ready to go. You can also remove it from the bed when not using it. But will be most costly compared to other types which are essentially truck toppers with built in pop up. The others I would have to build draws add a space for the fridge and do some electrical to have power. The benefit is that it can be pretty much customized anyway I would need. I was wondering if anyone had a pros and cons to either to consider. Thanks guys
Nebzy
Calgary, AB, Canada
Jamie
Neb
Just wondering what you chose? I am exactly in the same dilemma right now. 2 year wait on both go fast and vagabond and am tentative to put a deposit on either.
Any help or suggestions would be much appreciated!!
