OB1 App use on iPad
Hodgespa
Marana, AZ, USA
Erik
Drown
I've been having issues with using OB1 on my iPad. When using the map on my iPad I encounter a couple errors.
1. When first opening the map, I get the error "API key provided in request was not found." The map still loads and seems to look normal still except for the next error...
2. When selecting an icon, like a campsite, to get more information on it, it does not bring up any information but gives an error "The location information could not be retrieved. The location(s) may have been removed recently, or there was a connection issue.
I'm not sure if there are more errors that may be encountered because I can't do much else on the map after that. This is all under the "PLAN" tab as well.
You may already be aware of this, but I haven't seen any mention of it yet and would really like to have this working on my iPad! As an additional note, I did delete the app and try to reinstall it but ended up with the exact same results.
Reactions: Ubiety
Ubiety
Sammamish, WA, USA
Greg
Ubiety
Ribs
I think all of the issues that you mention are due to the first "API key provided in request was not found." issue. If you have not done any "Quick Saves", which save data locally, or are not worried about losing any "Quick Saves" you might try deleting/re-installing the app. I use OB1 nearly exclusively on an iPad and it has been working well - so there is hope ;)
Also, make sure that you have an internet connection and that OB1 is not it offline mode (see app settings). Check out the awesome OB1 tutorial videos that @Michael has been putting together to do a deeper dive into things such as OB1 settings.
Hodgespa
Marana, AZ, USA
Erik
Drown
Thanks for the response. I did try uninstalling and reinstalling. Same thing. However, once I logged out and then signed back in again, it is working great now!
So for anyone else that may run into this... it seems that logging out of your account in the app and then logging back in will correct this.
cookiedough
Phx, AZ
Dave
Petersen
Agreed @Ubiety - iPad Air 3, wifi only. Works well, but needs the gps connection through another device, otherwise works iPad OS 15.7, OB1 11.11.2
Reactions: Ubiety
cookiedough
Phx, AZ
Dave
Petersen
So for Christmas I purchased a Samsung Tab S6 lite, just for the gps receiver in the snapdragon chip. As a fully committed fruit user (iCloud, mac, iPhone, ipad) that on board gps makes things work much better than pairing my ipad with my iPhone or Garmin inReach.
Reactions: Michael
Rank IX
Benefactor
15,584
Murguia
KM6YSL
Absolutely!
Reactions: Kent R
cookiedough
Phx, AZ
Dave
Petersen
Just started another thread, my Christmas statement earlier is still great for routes which I alone am using. When I want to join another group trip, getting the trip leaders .gpx into OB1 on my tablet is proving to be a bit of a challenge.
