Northwest Ham Net
educky
That is a conundrum.... how about grounding out to the frame or body instead of the battery?
Going to use a Rear Seat Bolt, or the Bolt that holds the Jack down. I'll likely break out my continuity tester to check a few spots. Right now Im waiting for a smaller version of the Bluesea Box I currently have so i can mount it under the rear seat.
That should work... I’m waiting on parts for my Base Station build... I should be on the air Tuesday Night.
TerryD
Look for a ground strap coming off the negative cable between that load detector and the engine or body and land it with that.
There is a ground strap just below that sensor on my Xterra and that's where I have my radio ground.
educky
Has it been decided for a local group HAM, or have you decided on just jumping on the larger groups friday event?
Top
