My Cherokee XJ is stuck in four wheel drive
shawninthelawn
Buda, Texas
My friends and I were running my Jeep in Four lo going up a tall hill, and when we went to shift back into all time 4wd my shifter jammed. I had the Jeep in neutral and managed to force the lever into full time, but now when I try to shift back into 2wd the Jeep goes into part time four wheel drive. Does anyone have any idea how this could be fixed?
stoney126
Napa Ca
Robert
Stoner
What year is it?
stoney126
Napa Ca
Robert
Stoner
Going by the description it sounds like a 242 transfer case. When was the last time the flu is was changed. Have you looked at the linkage? The bushings get worn out and bind. You can remove the cable and manually shift it and determine if it's internal linkage or the shifter cable binding.
F4T XJ
London, United Kingdom
Paul
Savage
I would check the following
1. Measure tire diameter and if the front to rear is different adjust the pressures until you can match the diameter front axle to rear.
2. Check fluid level in transfer case.
3. Check selector linkage and adjust.
Also sometimes I find putting into 2WD or 4WD full time then a quick back and forth drive and reverse with a sharp prod of the pedal so the jeep moves about 4-5 ft in each direction helps.
Make sure the front wheels are facing perfectly straight ahead.
Sent from my VIE-L09 using Tapatalk
Reactions: Lindenwood
shawninthelawn
Buda, Texas
I've tried the reverse trick problem is my 2wd doesn't work at all, I can only get it to go into 4part time, 4 full time and neutral
