Minimal tool DIY roof rack
Shakes355
Bellingham, WA, USA
Adams
Very nice. Most useful rack is the one you have. A few things to keep in mind as you continue.
) Flex is the enemy. Even more so when using bolts for fixturing. Consider a vertical element to help fight twist.
) Loctite is your friend.
Keep the pics coming!
Reactions: ManitobaTacoma
Manitoba
Brad
Laidlaw
Thanks. Not sure if there is going to be much in the way of flex with how I plan on mounting it. But I will keeps your words in mind! I am currently letting the final coats of paint dry, then I'll be doing a final fitting, and figure out attachment points and retention points!
Will try to upload photos afterwards.
Reactions: Sparksalot
Manitoba
Brad
Laidlaw
I figured. Those things are like gold anytime I try to price one.
You're lucky if you can get them for a 1.00/lb, and especially if they are old manufacture, which tend to be better than the newer ones, unless you're buying high end which is $$$
Sparksalot
Influencer III
4,312
Bastrop County, TX, USA
Rex
Drake
KI5GH
Air Force
I've been glancing at them them on the used /garage sale pages. Most are closer to $10/lb. And appear as old in pictures. Both of my grandfathers had nice ones. But I was 1,500 miles away when they passed.
Manitoba
Brad
Laidlaw
Yeah, they can be hard to get a hold of. I bought mine off an old junk collector for 90.00 (it's a 90 ish pound anvil) so I got a good deal, but it's one of those things you just got to get lucky.
Manitoba
Brad
Laidlaw
UPDATE: Build is done, and rack has been installed. Might still need some tweaking, and did some Last minute after-thought add ons, but it is solid and doesn't look terrible. There is no roof clearance however, so I may have to lift it up on spacers.
