Front Runner Wolf Pack Legs
willnicks
San Francisco
What & Why: This is a Leg DIY for Front Runner Wolf Pack Boxes. I'm fan of the Front Runner Wolf Pack boxes and I use them for my camp kitchen. What I don't like is that they can take up a lot of table space. The alternative is keeping the boxes on the ground, which can be tough on the back or result in dirt and bugs in the kitchen. The boxes have deep channels inside that look perfect for legs and 1 x 3 (3/4 x 2 1/2 actual) dimensional lumber fits just about perfectly.
Cost: About 5-10 bucks depending on the wood you use and not including tools.
Materials:
  • Hand Drill
  • 3/4" Hole Saw
  • Saw
  • Sander
  • Sealer and/or Paint
  • Old corks
  • 1x3 lumber (I used cheap pine but hardwood would be ideal for durability)
  • Two straps.
Step 1: Cut your lumber to what ever size you'd like or get the hardware store to cut them for you. For this first set I found 48 inches fits my height. Also, plan ahead and check where the legs will fit in your vehicle. The lumber typically comes in 8 ft lengths for around 2 bucks each. Each length netted me 2 legs. I used a circular saw, but a hand or table saw would do just fine.
Step 2: Fit the legs in the channels sand/file as necessary. The channels on the long side of the boxes seem to be a tad tighter than the short side channels, so take this into account where you want your legs to be. I chose the short side. Sand/file for any unevenness in length if you desire. Probably not necessary since it will be on uneven ground most of the time.
Step 3: Completely sand the legs. You can sand at the end if you want, but my lumber was so darn rough it was necessary at this point due to splinters.
Step 4: Stand the the box up with the legs in the channels. You now have functional legs and can stop here if you'd like. Problem though, is each time you move the box, the legs want to fall out. So I did a couple extra steps to keep that from happening.
Step 5: Turn the box upside down and insert the legs until they stop. Mark a circle along the edge of the box hole. Remove the legs and insert the other end. Mark circles again.
Step 6: Take your hole saw and cut holes at each marked circle. Don't drill all the way through with the hole saw or you will probably splinter apart the opposite wall (like I did on one of the legs). Just drill enough so that the pilot bit comes through the other side. Flip the leg over and finish the hole where the pilot hole is showing.
Step 7: Sand the rough edges of the holes and refit the legs of in the box. Check to see that each leg hole matches with the box holes. Use a Dremel tool or round file if you need to do any resizing.
Step 8: Stand the box up with the legs inserted. In each hole insert an old and not too swollen cork. You may have to whittle the cork a bit. Once the corks are fitted, lift the box up to make sure the legs don't fall out.
Step 9: Wipe the wood down with a damp rag to clean it. Then finish the legs with a sealer and/or paint. Stain it first if you like.
Step 10: Once the wood has dried, stack the legs and insert straps into the holes for storage. Now they won't fly all over the place.
Step 11 (Optional): Find an old piece of nylon strap and staple gun/nail the ends in the middle of one of the legs to make a carry handle (for when the legs are strapped together).
stevet47
This is great, way to think outside of the box! I'd be interested in taking it a step further and make the legs just under 2x the inside length of the box. Then hinge the legs in the middle, a simple barrel latch would keep them from folding on you. This would only cost a few bucks more and would let you store the legs inside the wolfpack.
willnicks
San Francisco
That's a great idea.
GPsGeeps
Materials:
  • Hand Drill
  • 3/4" Hole Saw
  • Saw
  • Sander
  • Old corks
  • Two straps.
This is a great 2 for 1 DIY! I'm in for more table space and especially saving the back. Great job!
Road
On the road in North America
Whoa, very cool tip. I have four of those boxes and will be making a set of legs for one or more.
Thanks man, very cool hack.
Materials:
  • Hand Drill
  • 3/4" Hole Saw
  • Saw
  • Sander
  • Old corks
  • Two straps.
Reactions: willnicks
Anthroman
San Diego
Mark
Carrel
This is awesome. I also have four of these boxes that hold all my kitchen and pantry items. Looks like I have another weekend project to add to the list!
maxboxa
SF Bay Area
Jerry
Johnson
i wonder of a little strip of 3m dual lock would work to secure the legs. really, just need the adhesive to hold the weight of the legs when you move. should hold on the box/plastic side, but may need a staple or two on the wood side.
willnicks
San Francisco
I think so, it just needs a little bit of friction. Gluing some rubber to it or an o-ring/rubber band might do the trick.
