- First Name
- Scott
- Last Name
- Viking
- Member #
17968
- Service Branch
- Air Force Veteran
I have a Flexopower but haven't set it up and used it yet, it's charged and I'll probably run my fridge off it soon to test both out. I have questions thought, I wonder if there is a way you can add batteries to the Flexopower setup to increase total AH's like you can the Goal Zero Yeti 400 which has chaining ports? Also, has anybody noticed how cheap it is to get a high AH lithium battery pack with jump starters? If I'm not mistaken, the one in the link below is 180 AH, if you could connect that to the Flexopower you would have a lot of run time no matter what you were using. Am I off base, is the output of these jump starters different where you couldn't connect it to the Flexopower to add additional AH's of juice to it? Or could you just make your own solar generator using the 180 ah battery in the jump starter? I'm not an electrician so that's why I figure I'd start this thread so we could all talk about how to get the most out of our Flexopower solar generators.
