Looking for a shock/suspension experts here:
I have been kicking around the idea of my next upgrade, I need to replace the lower arms on my FJ Cruiser so I am going to upgrade them. That is happening, the decision has been made. I am going with the Camburg stock length arms. The question I have now is, do I add a bypass shock or an Air bump stop? I have the option of going either route and the fabrication needed to modify for either is about equal. My question is about performance, what I expect to do with the rig and what will be the best long term solution. My thought is to go air bump. here's why:
My biggest concern with adding a dual bypass shock is using it as a bump. I know a lot of people use them as bumps in that last pressure zone. I am thinking that's a bad idea. I am thinking shocks are not designed to be the limiting factor in suspension travel, the bump stop is and a limiting strap if you need that top end limit. Am I wrong? I know I will get more control over the front end with bypasses. I know I will get a better ride if properly tuned and so on but how will it handle the weight?
Air bump stops do the job of being the limiting factor in travel, reliving the shock of that work. They also absorb the energy in that last bit of travel smoothing out the bottom-out and the rebound. So there is a performance benefit. Given the extra weight of the vehicle, I feel bottoming out and striking the bump is way more likely IMO.
I could be completely wrong in all of this. This is based on my research and reading and asking local shops and so on. I am not looking to bomb through the desert at 80mph. But I am looking for the best performance option between the two and balancing that with reliability.
(Pics for fun)
(Pics for fun)
