Can I get by without 4x4
Natenite
Missouri
Nathan
knight
Ok. We are new to all of this. Have spent years backpacking and camping but I have kids now and am trying to figure out how to do fun adventurous family road trips. Also allowing for cheaper travel... in theory???
We have a 2003 Tacoma prerunner. Love it. Does not have 4 wd. I’m wondering if we can get by without 4wd and still see awesome stuff or is it really essential? We are still learning everything that’s out they’re to drive and explore in vehicle so I’m a bit clueless but I’m thinking things like the Mohave road or white rim trail or big bend. Cathedral valley in capital reef. Even things like the Ozark forest or Mark Twain forest near where I live. Could we get by with the electronic rear locker, some beefy tires (a lift?) and winch and good driving decisions or will the lack of 4wd be significantly limiting. Last thing I want is to strand my family in the middle of nowhere. I understand 4wd is better, my issue is these trucks are crazy priced, we got this one for a steal 9 ish years ago and I really don’t want to try and buy another if I can avoid it. I’m not a mechanic so trying to do the 4wd conversion is absolutely overwhelming to me.
Any constructive thoughts and experience would be greatly appreciated. Thank you!
Lacking 4wd will be limiting but it doesn't mean you can't have fun. You'll just need to be extra wise in your decision making and don't take unnecessary risks. Be prepared, walk the trail to check out obstacles, and, when in doubt, turn around. No trail is worth risking your family's safety.
Ultimately, many things come down to cost-benefit analysis. A new vehicle is very expensive; you are better off spending your money on some minor upgrades and buying gas for adventures. Once you hit the wall and your current vehicle is ready to be replaced, then you may want to consider 4wd. In the meantime, buy some off-road books and stick to the easy trails - generally they are just dirt roads without major obstacles or traction requirements.
Jaytperry89
Winston, OR, USA
Well it isnt that its required. Even with 4x4 I've been bogged and stuck. But I wouldn't get crazy with my family with me. It's a solid piece of insurance to help you get home. Throwing a locker in, bigger tires and a lift won't help by itself. I'd say if your going to spend the money on that kind of stuff just find a 4x4. Your just going to wish you had invested the money into it anyway. But that doesn't mean you can't get out and explore. Just take a few friends with you.
sabjku
Supporter
Alexandria, VA
Remember those family trips when we(some of us!) were kids in the wood-sided station wagons? No 4x4 there! Like others said, just go where you're comfortable exploring, and don't get into any situations that you'll end up regretting. It's definitely not necessary. More of a luxury than anything else, at least for most of us who don't do any real hard wheeling.
sgthusk
Williamsburg, Brown County, Ohio
KE8IZR
4x4 just lets us get stuck even worse further down the trail and really dig it in good trying to get out. Lol. As with 4x4 take recovery equipment and find out how far it can go. Find your own limits to. You can learn a lot that way. As you find limits then find the solution to get past them. That may eventually be 4x4. “Outfit and explore” Both are a growing experience. Be safe and have fun.
Reactions: Natenite
Hans Sommer
Arroyo Grande CA
Hans
Sommer
If you travel with friends and have recovery gear you can help each other out. I’d say stay on fire roads and do dispersed camping with the family and if everyone loves it invest in 4x4 but always travel with another vehicle to help each other out.
Anak
Sandy Eggo
When I bought my XJ it came with the front driveshaft in the rear hatch. Because that was where it fit. The P.O. had fabricobbled a pathetic excuse for a downpipe such that the front driveshaft couldn't be installed. For about two years I put up with only having 2wd. That didn't keep us from going out and having fun, but it did affect my choices. There were still good choices to be made.
If you have a good locker, a good winch and a good air compressor you can still get out there and see more than the average family. 4wd and no lockers can leave you stuck where 2wd and a locker doesn't even have to pause. I am sure plenty of us have been there. And don't underestimate the value of being able to air down for traction and then air back up later. Those are three relatively simple ways you can stack the cards in your favor without having to decimate the family budget.
I will however suggest that you pay attention to what the National Park Service recommends when it says that a particular trail requires 4-Low. That gearing advantage is something you are not going to be able to easily replace, and it does make a difference. Generally speaking it means that just because your Subaru has AWD doesn't mean it is up to the task of this particular trail. However, you are going to be facing the same challenges as the Subaru. Steep situations (either up or down) really do need that low gearing. You will need to accept your limitations on that front. But even with those limitations there are great places you can go. Just choose wisely.
Reactions: Natenite
Horse Soldier
Louisville Ky
No 4x4 no problem, I have a friend that has the same vehicle as you and all he has is and 8000 lbs winch and he keeps up with my Rubicon on easy to moderate trails. He is think about a rear locker. Not have having 4x4 is not a game changer. Have fun and Roll Tide.
The other Sean
Minneapolis
I'd invest in a set of traction boards, a shovel, a rear frame mount tow receiver and one of those D ring adapters for it and a decent snatch strap. . THAT will get you out of many situations. 2WD will get you hung up, but normally only to the point of either a quick tug from another vehicle, or where some shoveling and or traction boards will get you back out.
I remember one time taking my wife on this adventure WAY BACK in to the woods for this campsite I had found. miles and miles of trees banging on the sides of my truck and mud holes. We turned the last corner...... Honda Minivan parked there...... Turns out, I wasn't the B.A. I thought I was...... :laughing:
Craftman2
Salt Lake City, UT, USA
Good tires and a traction aid (like Maxtrax, Gotreads, etc.). You'll be fine.
The Cathedral Valley loop in Capitol Reef is one of my favorites. No 4x4 needed really, as long as you have a bit of ground clearance. When I did it in my old truck the only time I switched to 4WD was the stream crossing, but even then it wasn't necessary.
I did Fins and Things in Moab earlier this year with another couple in an FJ Cruiser. They didn't put it in 4WD at all during the trail.
With practice you'll get to know your limits and how to work around situations that might otherwise require a 4x4.
TerraRoamer
Richland, WA, USA
Stephen
Bell
It's great to see such good advice given! No sarcastic and useless diatribes!
I am really starting to like this forum.
As others have said, shovel, recovery points front and rear, and a source of traction (maybe sourced at the trail or you may need to have something on board. I would suggest an air compressor and deflation device. These don't have to be expensive but will allow you to lower the tire air pressure for greater traction.
Know your route and the requirements.
Even better, hit the trails with others who have recovery gear, and the knowledge to use it.
Familiarize yourself with the gear and safe use. Recover can be risky but injury can be avoided when proper safety is employed.
Important note: Use quality gear for recovery. Anything else may be putting you vehicle, you life, or someone else's at risk.
teufel hunden
Glendora, CA, USA
Ken
Harper
KK6BCX
My van is 2wd with a rear locker and regularly take my family out. I drive smart and understand the capabilities of my rig. I have however been places I probably should not have been in a 2wd 8k+lb. vehicle and only got stuck when I was trying to test the limits of my vehicle.
Add a rear locker and have fun.
Reactions: TerraRoamer
