Anyone have knowledge or experience with leveling kits for 2014 Ram Trucks? | OVERLAND BOUND COMMUNITY
SonOfNeptune
Springfield MO
So I went off the information I saw on the inter webs and moved to purchase BFG 34x11.5's for my 2014 Ram Power Wagon. After telling the shop, they ordered 34x12.5 R17 BFG's. Partly my fault in that I didn't double check them coming off the lot. Thinking I had the 11.5's it turns out that I have the 12.5's which ultimately rub on the control arm. Im looking for a solution to keep the tire from rubbing. Im thinking leveling kit for the front end... ultimately I think a lift would work but that is a lot more money than I prefer to spend. I have yet to get in touch with the shop that did the install (holidays and such have prevented me from doing so)
Any experienced knowledge would be greatly appreciated
stoney126
Supporter
Napa Ca
Robert
Stoner
I could be wrong but I don't think a leveling kit isnt going to help the rubbing issue. I believe you need a different offset on your wheels to move them out away from the control arms. Do they contact at full lock?
Wolvee
ᕕ( ͡° ͜ʖ ͡° ) ︻デ═一 pew pew
A leveling kit will stop tire rub to the fender at lock but not the rubbing on the control arm. For that you'll either need Hub spacers or wheels with a different back spacing.
Hub spacers will be cheaper but I'll always believe they're dangerous no matter how popular they are. They also put extra stress on wheel bearings but that may be inconsequential if you only get them wide enough to fit the tires.
The other option you have is more fun but more expensive. New Wheels.
I'd be riding on stock wheels right now if my 35's fit better on them. I never wanted to get aftermarket wheels because I didn't really want a "Pretty truck" but I accepted it and did it. The only real down side is now I take more pictures in Parking lots. lol
IronPercheron
Supporter +
Sweeny Texas
My buddy runs spacers, he has lost a wheel going down the road TWICEY
Yes TWICEY... google spooby < again...yes i said spooby.
Anyways... you need wheels with some back space cheif...
roamingtimber
North Cascades, Washington
I also agree that wheel spacers are not ideal. That being said, I have them on my jeep right now. They weren't in the the plans, but became necessary because of rear tire/shock issues. After a lot of research I decided that they can be safe. I retorque my spacers every 3000 miles when I change the oil and I use thread lock on them. The lug nuts on spacers are no more likely to come loose than those on your wheels, the difference is you can see the lit nuts on the spacers so they are harder to check. I also think that some of the bad rep that spacers have comes from the style of spacers that are basically just big washers. If you get the style of spacer that bolts to your hubs, then have a new set of studs coming out of them they are safer. But I still think that wheels with better back spacing is the way to go.
Reactions: IronPercheron
IronPercheron
Supporter +
Sweeny Texas
Thats hitting the nail on the head.
Because knowing the guy i mentioned... they are not being checked
Overland-Indiana
Kokomo
Iv'e used wheel spacers before, hated them myself. So i went and bought a set of Cragar Soft 8s and never looked back!
Byron Eby
Sacramento, CA
I would go back and raise a slight bit of hell because that is danger and expensive. More importantly, dangerous, in the worst case of a blowout.
