Anderson Plugs
WinterfellJK
Denver, CO, USA
Jon
Denver
In addition to the standard 7-pin trailer plug, I'm using an Anderson SBSX-75A plug with 4awg wires to recharge the battery system in my trailer while driving with max 800W from the alternator. I wanted this version of Anderson plug so I could have waterproof/dustproof connections for the trailer cable and on the bumper of my Jeep and it has metal catches on the side to keep the plugs wiggling loose from vibration. The SBSX connector also has the option to use four additional low current signal contacts in addition to the two high power contacts.
Has anyone used this style Anderson plug for any purpose, and if so, did you use the low current signal contacts? I was thinking to use it for an indicator inside the Jeep that the plug is connected, but I don't have any other ideas, so I may not use them and only wire in the power contacts.
K12
Trail Blazer III
6,000
Canyon County, Idaho, United States
Beau
K12
Air Force
I have not used those. I use a lot of the sb50 and the anderson powerpole connectors, and i have one sb150 for one of my solar chargers. The ones i have that have a low voltage goes to a small led light on the connector to show if its receiving power.
I love the anderson connectors, would definitely recommend them overjust about anything else. Im planning on putting an SB350 as a quick jump connection for the truck batteries.
Ebbs
Creator III
6,480
Spokane, Spokane County, Washington, United States
Brandon
Eberhardt
KE0JBH
Air Force 02-18
When I towed my trailer I used an Andersonplug with no issues, but stopped towing and removed it.
I actually use Anderson plugs inside now, but the smaller version. I eliminated all the cigarette plugs because of they're propensity to walk out. I'm using them for my fridge and 12v for my RTT (lights, charging electronics, and CPAP in the tent), as well as cooking area lights
I've got one of these https://powerwerx.com/panelpole-panel-mount-powerpole-black-dual
And then these crimped on to the bare wire after cutting off the cigarette plugs 150 Piece Assorted 15/30/45A Anderson Powerpole Case by Powerwerx
You'll need this crimper tool
Love it wouldn't go any other way
