I will be buying wheels and tires for my rig soon. I am looking for opinions on steel wheels and aluminum wheels, pros and cons. I am looking at pro comp steels and aluminum.
Benefactor
I need to go wider for 35 12.50 tiresI run the stock aluminum that came of my Ram. My thoughts are if it ain't broke don't fix it. Whenever I get around to lifting the truck I might change out the wheels but truthfully with a lift I can run bigger tires and keep the wheels. If you want wheels for style then go for it but as a matter of function I don't think it matters all that much. Unless you are pushing you vehicle to extremes then you won't see a difference.
Right now i have stock wheels and tires. I am lifting and going to a 35x12.50 tires. So I need wider rims with more offset to clear my fenders and frame.So ground clearance then?
Sent from my XT1585 using Tapatalk
12.5 wide tires don't normally fit on factory wheels, and the offset is normally an issue too. So he's needing at least a 8" wheel, and enough offset in it, to push the wider tires away from the frame and steering parts.I understand the larger profile for a lifted truck. I am trying to understand the need for width. From your description it sounds like it is a cosmetic want more then a need. Which is fine but it didn't address my question.
I understand that as well. But it is back to the question I asked. Is this a need? Modifying ones vehicle for appearance is all well and good but in the world of overlanding it isn't a need. Now if his overlanding vehicle did not get him where he was trying to go and this required modification to reach the destination that would be a need. So what does the vehicle not do now that the wider tire would fix? If the answer is nothing then this falls into a cosmetic issue.12.5 wide tires don't normally fit on factory wheels, and the offset is normally an issue too. So he's needing at least a 8" wheel, and enough offset in it, to push the wider tires away from the frame and steering parts.
Wider width=wider stance=more stability. Cosmetic is the least of my concern. My concern is weight and strength. Steel or aluminum, I will buy the same size. 15"X10".I understand the larger profile for a lifted truck. I am trying to understand the need for width. From your description it sounds like it is a cosmetic want more then a need. Which is fine but it didn't address my question.
