2015 Schutt X-Venture XV-2
Unit sold as-is, has some wear and tear. No accidents. Beige paint with white vinyl wrap. Currently registered in California and stored in Orange County.
Everything operates properly. If you choose to add the in-line hot water heater, the unit (hot water heater) will need to mount on the interior of the cargo bed on the right rear panel.
Tent, awning, wheels, tires, electrical system and fridge all remain with the trailer and sold as one package.
XV-2 trailer with extensive upgrades, all professionally installed.
Length-151.5 inches
Curb Weight-1200lbs
Width 79 inches
Payload Capacity-2300lbs
Height Adjustable-elevating roof rack
GVW-3500lbs
Electric brakes
Nose box-front cargo area has three compartments, one with batteries and electrical system, one with power inverter and charger and one with ARB fridge. Has 12v socket outlet and USB interfaces
Cargo Bed Interior-59 inches x 89 inches x 18 inches
Axle Clearance 17.5 inches
Distance Between Wheel Wells-49 inches
Construction 6061-T6 Aircraft Grade Aluminum, Alcoa huck bolts
Rear self-leveling plates and arms with lock pins
80/20 universal rack
Rigid LED rock lights
Propane system (water heater ready), with 20lb propane cylinder
Area LED lighting-Rigid LEDs
Method Wheels NV305 / 17x8.5 - 6x5.5 - 0/4.75
New Tires: (2) LT285-70-17E BF Goodrich KO3 tires
New Axel/Suspension: Independent Rubber Torsion Axle (Dexter 3500) axle
22-gal water system, with water pump, shower or hot water connection on passenger side, with Alu-Cab shower annex
ARB air-compressor
Line-x black coating
Kilby 6k max coupler, 360 degree articulation and fits any 2" receiver
Independent mechanical brakes with lever arms on each wheel
Side galley-table with faucet, water basin and cut out for propane burner stove (included), goes on the driver side.
Rolling soft tonneau bed cover
Roof top tent: Alu-Cab Expedition Tent, 96” L x 63” W, 51”H
Awning: 2m ARB awning with ARB annex room
ARB 50qt fridge (fair condition but fully-functional)
New ARK XO 750 black trailer jack
Custom electric wiring, solar charging system: Braille Fleet G34 deep-cycle lithium battery, 180W Sunflare solar panel, Victron Energy BlueSolar MPPT, fridge wiring, internal wiring to all components
SCHUTT - BEHIND YOU ALL THE WAY
www.schuttindustries.com
Length-151.5 inches
Curb Weight-1200lbs
Width 79 inches
GVW-3500lbs
Electric brakes
ARB air-compressor
