- First Name
- Donald
- Last Name
- Diehl
- Member #
0745
- Ham/GMRS Callsign
- WRPN 506
Stupid dimwitted me, I didn't even realize this thread existed until recently. So, here goes::
Slee short bus front bumper, Slee rear bumper and tire rack, and Slee sliders.
Shocks:
front OME 60070L sport shock (or TJM 650GBL120)
rear OME 60071L sport shock (or TJM650GBL220)
Springs front OME 850 “J” rear OME 864
front axle rebuild at 203,000
new front pads then at 248, not needed, but I like to swap in new ones at about 2/3rd wear or just before a long expedition.
New rear rotors, e-brake shoes, and pads at 238,000
Slee 3 degree castor bushings
New tie rod and ends
All new rubber throughout vehicle at 203,000 miles, including door seals, hood seals, breather hoses, etc etc.
Bypass kit for the PHH
Removed rear heater lines
Magnaflo Cats #51205.
New Denso A/C
New Radiator
New power steering pump
BFG AT KO "E" 285/75/16 (5 each)
Superwinch Tiger Shark 9500 SR ( viking winch line with viking thimble )
LED Door lamps: 194
LED Dome de3175
KC Fog Beams
800 watt power inverter
Dual battery tray and relocation Kit (Slee)
Dual Batteries,, Duralast Platinum AGM (34r)
Blue Sea 6 bank fuse block
Engel MD 14
TSL Plate and slide lock
Frontrunner Slimline II full rack
Frontrunner Awning
Frontrunner propane tank mount
150 watt solar panel
Pair of TREDS 4wd recovery boards
Shovel and mounts
Hi-lift
New paint job ( body-Quicksand / cladding- rustoleum rattlecan "espresso" ) and minor body work
Weathertech floor mats
Kenwood stereo with all new speakers with 300 watt powered subwoofer
Home made drawer system
Front seats re-upholstered in matching leather
What does it need?
I'm debating on whether to drop the trans and install a new rear main seal.
I'm debating whether to replace TCC gasket and front crank seal.
I'm debating whether to add a snorkle.
I have done, and will continue to do, all my own mechanical work.
Painting the body, body work, and upholstery I leave to the pros. I did paint the cladding myself with my wife's help. She has also assisted with all other mechanical work as well and doesn't mind getting into it, up on a stepladder and down into the engine bay, or down on the floor and underneath... How cool is it to have a gal you can take to a formal, take to the outback and live in a tent for weeks on end, and take to the carriage house to work on our rig?
I may have forgotten something as I copied this from by own build list, but deleted the itemized cost of everything. Of course, I neglected to mention a lot of regular maintenance items.
Here is the Diehlmobile parked in front of a clients house.
Shocks:
New Denso A/C
New Radiator
LED Door lamps: 194
LED Dome de3175
KC Fog Beams
Engel MD 14
Frontrunner Awning
Shovel and mounts
Hi-lift
What does it need?
