I use and carry a black steel wok and one low sided skillet for my kitchen kit. I previously carried several pots from my former light-weight backpacking days. But after adding the wok and realizing that, after several trips, I was using the wok 90% of the time as both a skillet and pot, i ditched the extra pots completely.I'm considering adding a wok to my cooking kit, anyone else added one?
Pros and Cons?
They look unreal, I've seen some really good dishes cooked up on those, nice and simple.Check out southwestdisk.com. Best system out there.
Sent from my SM-G950U using Tapatalk
True, packs up small but provides equally small cooking realestate too, especially the frypan/skillet.I have the equivalent cook set but from MSR vs Snow Peak. Found them either too small or typically unused which led me to use one of our in-home woks I already owned. Haven't regretted the wok addition - ever!
Best of luck!
I have a SOTO Muka (15800 BTU) stove or the campfire, hopefully either will prove enough.I have been using a wok at home for the last year but I also have a 80,000 BTU wok burner.
That should be good, it’s twice what most home stoves can put out. Do a search on how to season the wok, that is key.I have a SOTO Muka (15800 BTU) stove or the campfire, hopefully either will prove enough.
Todd & Meg, just a thought (me thinking outloud here)... I'd be a little bit hesitant to use the high heat + wok combination inside a teardrop - or for that matter under the hinged rear kitchen access door (design i typically see).I have been using a wok at home for the last year but I also have a 80,000 BTU wok burner. We haven't bought takeout since.I would like to use one in the teardrop I'm building but haven't picked a stove yet. I think I might be spoiled with the high heat I can get at home.
I have two woks, a carbon steel one (and @Eric Neal is right no soap. Ever!) that I use for cooking and deep frying. And a stainless steel one that is just used for water. I found boiling water in my carbon wok would take off the seasoning I work so hard to keep. I will try a wok once I get a stove and if I can get high heat I'll have one. If you live in an area big enough to have good asian markets check them out for cheap woks and accessories.
We did the camp cookware sets for years, one of the reasons we wanted the tear was to have room for what we want. I bought heavy stainless clad pans from a restaurant supply. Great pans and cheap, and are just as nice as the allclad we have.
Tell me about it! However - I am planning on ordering the Snow Peak black steel wok - its a tidy 300mm with a detachable handle. Bit pricey but their black steel is nice and the size should be quite good for us.damn they aren't small
All good points. We won't be cooking inside the teardrop. I haven't figured out the galley yet but I'm planning on having a spot on the side, outside of the galley to mount the stove when we get to camp. All my wok cooking at home is done outside year round.Todd & Meg, just a thought (me thinking outloud here)... I'd be a little bit hesitant to use the high heat + wok combination inside a teardrop - or for that matter under the hinged rear kitchen access door (design i typically see).
Reason? The amount of released moisture and food/oil vapors are going to get distributed inside the teardrop and then adhere to the interior surfaces which will become grimy and sticky- over time.
I'd prob use a dedicted outside only, free standing stove so all the smoke and moisture are released into the atmosphere vs into your sleeping space. I KNOW... ONLY one man's opinion, just a thought for consideration.
EDIT: just dawned on me that the typical teardrop trailer has a separate space for sleeping quarters vs kitchen hatch... so what i was thinking about grease/grime doesn't really apply like I was thinking earlier. Please disregard my comments here. ☺
Bottom line is that I'm a bit lazy and wouldn't want to add another "chore" to the "when we get home" list such as wiping down all the walls, ceiling, cabinets, etc. so as to avoid grease and grime buildup.
Best of luck!
Your description sounds very interesting. Can you attach a pic or two of the "grill pan" you describe? I too use the standard wok as my primary utensil for cooking but any potential improvement would be welcome.I do use a flat bed wok. It was coming with a grilled pan that fits into the wok (good for storage) made for friying things, so overland fries are great ! I find it useful for draining the pastas as well.
I actually use it as my main cooking gear along with a pot. I think the versatility of it make it perfect.
