Where to start vehicle wise
Michael_USMC-USAR
Mora, Kanabec County, Minnesota, United States
Diaz
USMC
So I joined this group in hoping to meet other overlanders near me. I live in Minnesota and wonder if there are any groups around me. My wife and I have toyed with the idea of building a diy overlander from a fire department or national park ambulance. At the moment, I just want to get out there and start learning and growing. I have a 2016 Dodge Durango that I am willing to do some mods on, however they are not easy to find. I have a 1998 Dodge Ram 1500 but the engine and tranny both need work to become dependable. So, in your humble opinion, should I put my money towards the eventual ambulance, find upgrades for the Durango, or buy something that is halfway there already.
Thanks for your feedback!
K12
Trail Blazer III
6,000
Canyon County, Idaho, United States
Beau
K12
Air Force
Best thing to do is get out there. I would suggest starting in the Durango as it is more reliable. Start small make sure you have the essentials (food, water, shelter, maybe heat in MN spring/winter). Figure out what works for you what are the things you realize you need, what are quality of life things that make the trips more enjoyable. As you go out make the list of things you want to bring and when you get back note the things that wearnt thought about or touched. Over time you will build the neccessities list and things you would like in your current setup or what you want in the future conversion plans.
The most important part is to get out in nature and enjoy it and leave it better than you found it.
highboy4x4
Naples, FL, USA
Russ
Derr
Army (ret)
Best advise I’ve heard in a while. Although it seems like common sense it’s full of wisdom. Get OUT there and do it. Figure it out as you go, make those lists, find what works for you, be adventurous!! Be flexible with time and effort and ENJOY!
Viking1204
Fort Walton Beach, FL
Viking
Air Force Veteran
Where are you at in MN? I grew up in SE MN near Rochester! Been living in NW Florida since 1992! Best advice has been given already, get out there in the Durango and see how far you want to go with a build!
Reactions: Michael_USMC-USAR
Michael_USMC-USAR
Diaz
USMC
I know where Rochester is, used to work in that area a bit. Now I live in Mora, about 1.5 hours SSW of Duluth.
ssouthard
Clark County, Ohio, United States
Southard
Update: My wife and I have decided to work on our Truck to be our overland vehicle. The Durango can stay as our daily driver. We do have a smallish old camper that we are going to Gut and convert to an off road camper.
Making memories is what it's all about! Send us some photos of your next adventure!
socal66
Covina, CA, USA
Carl
Sampson
My first "real" overloading vehicle was a 2000 Dodge Dakota Quad Cab which shared the same platform as the Durango. The only "mods" that I did was put on good all terrain tires and install a tonneau cover over the bed to keep all my gear out of the elements. I was able to take it really much on most trails out there including the White Rim and Elephant Hill in Utah and several backcountry trips in Death Valley, etc. The most important thing that was mentioned before is reliability. If you're going to be in the middle of nowhere you don't want reliability issues.
Michael_USMC-USAR
Diaz
USMC
I will do just that.
Michael_USMC-USAR
Diaz
USMC
My Durango is a 2016. They don’t really carry much clearance. The Dodge Ram 1500 is a ‘98 and already 4x4. The only issues I am sure of at the moment is either a corroded or loose wire in the dashboard, and I had a transmission light come on. And the lack of power. The power could be a bad MAP sensor, a leaking intake plenum, or a clogged catalytic converter. It only has 130,000 miles on it. Otherwise she drives fine.
The Deputy
Michigan
Long
Gone
My advice...DO NOT, repeat...DO NOT...buy an ambulance. Worked at a shop where we maintained and repaired the local fire departments vehicles. No one, repeat...no one wanted to work on the ambulances. They are a complete and utter nightmare under the hood. Most have dual alternators, dual A/C compressors and wiring upon wiring. All of the wiring upgrades and additions looked to be done by a kindergarten class. One of them needed a waterpump once...and l just about quit.
The Durango sounds like your best bet. Remove rear seat, make a elevated sleeping platform, with storage underneath for plastic tubs...and go. Expensive moification aren't really necessary...to overland. And most can be built...not bought. Search out 'overland build' projects for your model vehicle ...you will be amazed at how many folks have walked the path before you.
Good luck, and thank you for your service!
ssouthard
Southard
My advice...DO NOT, repeat...DO NOT...buy an ambulance. Worked at a shop where we maintained and repaired the local fire departments vehicles. No one, repeat...no one wanted to work on the ambulances. They are a complete and utter nightmare under the hood. Most have dual alternators, dual A/C compressors and wiring upon wiring. All of the wiring upgrades and additions looked to be done by a kindergarten class. One of them need a waterpump once...and l just about quit.
Absolutely agree! I drove and worked on them.
Reactions: The Deputy
Rubicajon
Creator III
4,572
Panama City Beach, FL, USA
Rubi
cajon
KG5VLS
Navy Seabee’s
You could always ask for a ride from the Navy members. :laughing:
Just start with what you have and build from it. Cover your basics food, water, shelter throw in your first aid training, self recovery and mechanical knowledge of the vehicle your starting with.
Best advise i can give is to stay away from analysis paralysis. Thinking too much about what you need or is this the right piece of kit will always keep you off the trails.
Michael_USMC-USAR
Diaz
USMC
Thanks! I will check those out.
