What would you do here? Simple Skin Avulsion [WARNING: POST CONTAINS GRAPHIC IMAGES]
El Solis
Livermore, CA, USA
KK6CQE
Here is a simple skin avulsion, something that could easily happen on a trip. What would you do? How would you address the wound? What supplies would you need to properly care for this wound? Do you carry enough supplies to care for this wound for more than one day?
In this case I just washed the wound with soap and water, patted it dry and then was able to lay the skin out where it belonged and apply a skin glue. If this was in the backcountry, I would do the following:
  1. Get my Basecamp First Aid Kit (FAK) and put on my Personal Protective Gear of at least gloves. Probably don’t need a mask or eye protection.
  2. Wash the wound with water and soap. Drinking water is fine, you do not need sterile water. Please do not wash these wounds with hydrogen peroxide as it will damage the healthy tissue as well. Just plan water or soap and water is sufficient.
  3. I wound then lay the skin out where it is supposed to be using tweezers.
  4. If you don’t have skin glue, and no…crazy glue is not the same, I would then lay down a non-stick pad (a brand name is Telfa or you could use Xeroform which is gauze with vasoline) and then tape it down.
  5. Keep an eye on it. You want to watch for infection which is usually present when the following are found: redness in the area but there can be red streaks that move away from the area, warmth, pus, increasing pain, increasing swelling.
  6. For this wound I would leave the dressing in place for at least 48-72 hours and try to keep it dry to allow the skin to “reattach”. The odds are that the skin that is lost will eventually die but it will be a protective barrier.
If you have any questions or suggestions for topics please let me know!
slomatt
Bay Area, CA
Are there any alternative dressings you would recommend if a non-stick pad is not available? I'm assuming a standard gauze dressing would not be ideal since it would stick to the wound and be difficult to remove. Trying to determine if it makes sense to add non-stick pads to my first aid kit.
Thanks as always for posting these scenarios.
El Solis
Livermore, CA, USA
KK6CQE
A non-stick would be the best but in a pinch you could use regular gauze but when you remove it you would want to soak it with water first to help keep it from sticking. It wouldn’t be the end of the world if the skin came off a few days later. This wound did well and the skin survived but I had expected it to die. If you did a good job cleaning it you could leave the dressing on for 48-72 hours before changing it (of course checking for infection). This gives the wound time to start to lay down the matrix for new skin and secure the flap.
Another option is to cover a piece of gauze with vasoline and the put that on the wound. Commercially it is called Xeroform. A similar product is called Adaptic.
Another option, and I’m only throwing this out there so people can see there are many right ways to do things, is to use the butterfly bandage or steristrip tape to hold the wound down. If you did this you would leave them in place and let them fall off on their own. I don’t carry butterfly bandages and I might have a pack of steristrips. Non-stick gauze is really something you should have in your boo boo and basecamp first aid kit.
PS: if there’s a topic anyone would like addressed please just ask! I’m happy to answer any questions related to trauma, first aid, medical care, general health care issues, etc.
Reactions: slomatt
Jedi
US Northwest Region Director
Supporter
Ferndale, WA USA
Brian
McClory
K6JDI
I recommend throwing some Tefla pads in there. The non-stick capability is nice to have for anything that bleeds and needs to be covered.
The other Sean
Minneapolis
Your mention of using Vaseline, is there any worry about causing infection from using an already opened tube or tub?
When my son was born and when they sent us home just after he was circumcised, they had us put a dab of Vaseline on a gauze and put it over the area so it wouldn't stick to his diaper until it healed. it worked quite well. The hospital sent us home with two tubes of Vaseline that had a fancy name on it.
Also, the more topics you are posting, the more I realize I know very little. The bit about not using peroxide on it is something I didn't realize.
Reactions: Empe Overland
El Solis
Livermore, CA, USA
KK6CQE
Vasoline is pretty safe from an infection standpoint. Not much will grow in it.
Was the tube of stuff “petroleum jelly”? Or something else?
You can get single shot tubes of vasoline but I don’t think you need to. For most people here we aren’t off the grid for weeks at a time. If you got hurt day one you’d be back to civilization in a day or so.
As for the knowledge part, shoot me some topics you’d like to know about and I’ll get some videos or post out. We are working on a formal training program for OB so keep an eye out for that as well.
The other Sean
Minneapolis
It was petroleum jelly (finally remembered to look for the extra tubes before little guy went to sleep, 4 months old now). I figure if it works on a 4 day Old's sensitive area like that, it must be ok for other things similar? I remember it did work well keeping the dressing off his wound until it healed up a few days later.
As far as topics, there are many scenarios many of us would never think of that are somewhat common out of doors, so I wouldn't know where to start as far as ideas.
Stewart (Stu) Pirie
Laurencekirk, UK
Could you do a write up on puncture wounds (Ive seen someone who fell on a stick whilst winching and penetrated the thigh) and perhaps larger bleed wounds like a chainsaw cut?
Ive had some training in regards to these both in a medi training course as part of my Anti poaching unit, but its always good to keep the brain topped up on info.
El Solis
Livermore, CA, USA
KK6CQE
MunsterGeo Overland
Mid West Ireland
C
Could Cling Film ( as we call it over here in Ireland and the UK and what you probably call Saran wrap) be used as a non-stick material in this senario and overwrapped with a typical bandage or tape? Assuming the area had been adequately cleaned of course.
El Solis
Livermore, CA, USA
KK6CQE
Technically it could but the cling wrap doesn’t breath and that might cause issues with healing. Really the goal is to reposition the skin and then hold it in place as best as possible. There are lots of improvised ways to accomplish this.
MunsterGeo Overland
Mid West Ireland
C
Brilliant, thanks for taking the time to reply and explain.
I asked as for a camp situation we would have Saran wrap in our camp First Aid kit for burn treatment and was curious when I seen your interesting scenario post.
On the hills and mountains here in Ireland the injury you used here is very possible as there are many areas with loose shale. Lower leg and lower arm injuries of this sort would be most likely on the descent in sunny weather as a lot of casual hillwalkers switch to shorts and tee-shirts..... You can imagine the rest....
Reactions: El Solis
El Solis
Livermore, CA, USA
KK6CQE
Bacitracin is one of those it doesn’t really hurt to use it, probably not needed if the wound is cleaned and kept clean. Better for road rash, scrapes and shallow cuts. I don’t routinely use it but I carry it.
Reactions: HOT-ROD
Rogue7
Pueblo Colorado
Randall
Glach
Xeroform is considered an occlusive dressing. As infection is a primary concern with a wound of this type, an occlusive dressing is not suggested. A telfa or gauze dressing and frequent dressing changes would be best.
To close the skin, steri-strips or thin tape strips are best.
As a last resort, use Duct Tape. Every adventurer caries it!
Reactions: Jun Dinsay
