That depends on what he's trying to measure. If he wants to know alternator output voltage, then that's as good a place as any. If he wants to know the kind of voltage being supplied to his accessories, such as radio, acc plug, or other interior do-dads, it should be tied into the interior fuse panel. Since the fuse panel is generally fed with a single large conductor wire (smallest mauf can justify) and is used by so much in the vehicle, you can tell if you are getting a big voltage drop because of added accessories inside.
It may be useful to have multiple feeds, (battery, OEM fuse block, AUX fuse block, ect) all selected by a switch. Then you can select which area you want to monitor voltage in. As always, use fuses at the source of each of your feeds and remember that the longer the run, the less voltage will be available at the meter due to voltage drop across the wire. Not that big a deal, IIRC, because the volt meter is such a small load, but just something to keep in mind.
