Ultimate Overlander?
  • Guest, You can choose a light or dark theme that works best for you with the "Style Chooser" botton at the very bottom left of this page!
resqr1
Traveler II
241
Omaha
I just found this on Craigslist. Not an attempt to sell. It's definitely not mine. But HOLY COW!!!!
All the goodies...
2018 Overland Street Legal off-road expedition vehicle –
- Currently Licensed in Arizona 2018
- 454 Big Block – Fuel Injected dry sump American-made Chevrolet Performance Parts 454 cast-iron engine Block (approx. 550 Horsepower)
- Full Tube 1.75 Avalanche Engineering 4130 Chromoly Chassis
- 208 Transfer Case –Hi and Low Range
- 25 Gallon Fuel C
- Fully caged
- all the sheet metal is 14gauge PNO and 1/8” PNO
- Automatic Transmission - Turbo 400
- Custom Leather Seating
- High Output Heating / Defrosting
- 4” Exhaust
- 4 ft Cab clearance
- On board Compressor – dual Tanks
- 46 inch Baha Claw Tires
- 20” OMF Bead locks (street Legal) 5
- Storage Box’s – Tool bags- Tow Straps
- Removable Tool Box’s
- Custom Stereo System with subs/amp
- Coil Over Suspension
- Limiting Straps
- Fully Plated under carriage with diff guards
- Dana 60’s axles (4:88’ gearing) H1 Pumpkin’s
- Extreme Drive Line’s
- Rock Guards
- K-N Air Filter
- Military Key’d Ignition
- Military Brakes
- Off Road Lighting ( overhead, under fenders, rear)
- Windshield Wipers – Horn – Tail Lights
- On demand rear steering assist
- Car Cover
- Wheel base is : 125" x 15'l x 89"w x 7'7" h
- Weight 4100 lbs approx.
- James Baroud Evasion Roof Top Tent All information can be found here: Evasion — James Baroud USA
* EVASION OUTSIDE DIMENSIONS
Length 78.5"
Width 55.5"
Height Open 13.5"
Height Closed 41.5"
EVASION INSIDE DIMENSIONS
Length 78"
Width 55"
Height 41"
DESCRIPTION
The Evasion hard shell rooftop tent offers a new way to look at vehicle adventures. With its larger overall internal space, the Evasion provides comfortable space for adults to sit upright in either end of the tent. With its full 360 degree panoramic windows, air circulates freely though the tent in warmer climates. For extreme conditions, ventilation can also be assisted by the solar powered ventilation system. Access to the tent is easily gained by using the telescoping ladder that comes standard with all James Baroud rooftop tents and can attach to either side of the tent.
Ladder- Access to the tent is easily gained by using the specially-designed telescoping aluminum ladder. Our unique design automatically adjusts to the height of your vehicle and prevents bending while you're in the tent.
Easy to drive
- A 550 Horsepower Engine and all-wheel drive system ,Hi / low-range gear set, keep the truck moving forward through any conditions Mother Nature can throw at it and has the brute power and deft motility to tackle terrain of all kinds on the adventure of any hardy Families choosing.
- Along the way, it can stop at campsites or simple roadside pull-offs, sleeping off the ground comfortably on the bed and comfortable, no matter what's happening outside the windows
