Tundra or 80 Series Land Cruiser ?
Line guru
San Jose CA 95123
Alfredo
Garcia
I really appreciate all the feedback, that's exactly what I was looking for. All have point out very specific things to take in account as far as what vehicle I should focus on. In this case I should just keep building the 80 .. since I just got it I don't know what kind of maintenance it has seen by the old owner. All exterior looks clean and I know the last owner which he pointed out what he worked on. He just needed a bigger truck after about a year of owning the 80.
Thanks all
MOAK
Donald
Diehl
WRPN 506
We are saying the same things. However I am responding to your comment
Replacing all the consumables is needed, that needs to be figured into a 27 yr old vehicle. Just because it's a 80 doesn't mean it will be reliable and continue to be.
All i'm saying is, exactly what I said. You have to keep up on all the consumables.
The economics of it were not my point of discussion.
Also, I said as much in the post just above what you quoted.
True, however, the driveline itself will last as long as an old Farmall tractor engine. Certainly there are all kinds of parts that will need replacing over the years and /or rebuilt. but the heart of the beast is nearly indestructible. I’ve yet to even hear about a bottom end, transmission or third member failure when utilized and maintained properly.
The Roach ...
Frisco, TX, USA
V
Sensible comments on the age of the 80, however also on its capability, better access to some places, etc. I'd follow the advice of others who've said fix the 80 and expect to do some maintenance. We had an 80 in Africa for 2 years, took it all around Southern and Eastern Africa, and it did a great job. Yes - we had to replace the radiator, front differential, and A/C fan motor, but I wouldn't take a Tundra on the same trip.
Exactly the point I keep trying to get into people's heads. go out and TRY to find a as capable platform as the 80 or 100/105 series LC. Honestly, you can't. I looked at the new defender 100.. and like it. but started doing the math. all up a new defender with all the kit will go past 150k.
you can COMPLETELY rebuild to a new spec ANY 80 or 100 series LC for less money. I spent most of the last two days looking at costs of building my 23 year old OWNED series 100 into a diesel powered (toyota v8 Twin turbo) with a solid front axle AND refreshing the WHOLE suspension / drive train. cost? 35k. sound expensive? well, look at the torque, fuel economy/range, reliability factor AND having a completely spec built truck! SO, I am working on the overlanding parts sliders , bumpers, lights, electrical systems, storage systems, radios, navigation (most I already have).. and when the mechanicals start to go crazy. I roll it into a shop and spend 35 to 45k on a total spec out.. and get EXACTLY what I want.
A totally capable of going ANYWHERE overlanding / expedition truck with zero miles mechanical.
I looked at the new jeep hybrid wrangler, diesel gladiator, defender 100 -- even old defender 100/130's and doing the spreadsheet on the buy / build outs.. staying in a LC just makes sense... if you aren't making monthly payments to fund your insanity. the battle of few $ each month vs. best built truck total cost. that is the issue most people avoid looking at.. now vs. when its done and over.
MOAK
Donald
Diehl
WRPN 506
The only conundrum is when to rebuild? 400-500-600k miles? Another conundrum? Which engine & drivetrain? My first impulse is to keep it stock, however, there are a lot of options. The 2.8 Cummins comes to mind as does the stock HDJ 81. I’m just a bit leery of swapping to the Cummins until some long term reviews start coming in. Let’s face it though, our 80 series Landcruisers are trucks and most people don’t like trucks. ( sorry, the new pick up trucks on today’s market are nothing like an old school truck)
The Roach ...
Frisco, TX, USA
V
i've heard ALOT of bad things about the 2.8 Cummins. but you could drop a Toyota d4d and a sixspeed into it pretty easy.
as far as when.. I have the 1500.00 rule. if the total cost of work on engine or trans is past that. I look at a repower
Reactions: Jeremy M.
Alanymarce
Trail Mechanic III
1,392
Colombia
In general I believe that it’s best to stick with the original design (motor, transmission, etc.) with a few exceptions- a well-proved suspension upgrade for example. Vehicles are designed (at least in the last few decades) for all of the components to work harmoniously. If you add more power then the risk of overloading the transmission increases, if you add a lot of mass then the structure may end up over-stressed, if you increase unsprung weight the handling will suffer, etc., etc. The LC80 is a very capable vehicle in standard form. If it’s deemed to be inadequate in some significant way, then it’s better to select a vehicle which fits the objectives rather than try to turn it into a different vehicle, in my opinion.
POPO AGIE
Riverton, WY, USA
Bill
Stephens
I am the original owner of a 1978 FJ40 that I totaled in 1991.
I have started rebuilding it and started with replacing the rear axle from a FJ60 that is converted to a full floater and disc brakes with a LockRight. New double splined axle shafts.
Then rebuilt the front axle and installed a big brake kit that achieved widening the track to match the rear axle. Installed a high steer set up and FJ80/105 power steering box FJ80 tie rod ends with DOM tubing tie rod and relay rod. Installed a LockRight in the front. RVC axles with 30 splines through out in the front and HD Aisin lock out hubs. FJ60 knuckles were installed with 25mm trunnions and bearings.
Replaced the 4 speed and one piece transfer case with the Toyota H55F transmission and split transfer case with 3:1 low range. With the 4:11 gears front and rear I have better low gearing and an OD in 5th. I also kept the parking brake on the output of the transfer case so I only have 1 brake drum to worry about and disc brakes at the axles.
I mated a Cummins R2.8 to the 2F bell housing and that conversion retained a de-massed Cummins flywheel with a hub to bolt the 2F flywheel to. Ordered a Terrain Tamer HD diesel clutch and installed.
I used as may Toyota parts for this build and most everything is still available.
So from the motor to the rear end it has been mechanically replaced or upgraded to be a reliable as possible. I am too old to walk home.
Reactions: El-Dracho
MidOH
Mid Ohio
Clark
YourHighness
Keep the LC. Sell the Tundra. Rebuild the LC as needed.
You can find a Tundra anywhere, anytime. Theyre about as special as a cheeseburger.
I dont get the dust thing. Seal your boxes, get a truck camper. All the gear in the bed of my truck is crated up. Corrosion is the only enemy.
MazeVX
Gießen Germany
Mathias
Kreicker
What's the best platform to overland?
I have two options to build a rig. 2016 tundra and a 94 land cruiser with triple lockers. Base on experience overlanders, what is the best platform to go with?
Any advice or recommendation would be greatly appreciated.
Thank you all in advance.
Merry Christmas!!!
Both are great, if I was to build them, they would be completely different.
So what are you planning to do?
Go really far or staying in north America?
Tundra would be ideal for a canopy camper, huge benefit in bad weather.
While the 80 locks you on a tent, which is something that you have to like or not.
POPO AGIE
Riverton, WY, USA
Bill
Stephens
Merry Christmas!!!
My preference would be the Land Cruiser and most parts are still available if a vender cant get them you can search other countries with eBay. I have found parts in Poland and OZ for my 78 FJ40.
Since I am rebuilding mine and have installed a FJ80 power steering box I dont need the 16" steering wheel and found a FJ70 refurbished wheel in Poland and I am moving the parking brake lever to the floor and had the split transfer case assembled with the parking brake like the 4 speed had. I found a short cable in OZ and the price was reasonable.
