Tube vs. Tubeless Tires?
rking.1688
Ohio
Ryan
King
So the Willys truck project has stumped me again. In the essence of keeping the truck more original, traditionally the truck would've ridden on 6.50-16 bias ply tires. I have also thought about more modern 31x10.5r16's. Both are readily available, but which is the better option?
If I go tubed, I can carry more spare tubes/patches so long as I don't damage the tire badly. At the same time, a bent rim because a much smaller issue as well. Tubeless however would probably be much more reliable at lower PSI, and if you have a full size spare and a patch kit, it's a pretty simple fix compared to knocking a tire off the rim...
Thoughts?
The other Sean
Minneapolis
How much on road travel will you see? In all honesty, how "available" is the Bias tire? I always look at needing a tire in the middle of nowhere, finding a corner garage in a one horse town. On my last truck, that is why I went with 31's and not 32's despite knowing 32's would fit. I knew it wasn't a common size and may run in to issue needing a tire in said situation. Any tire shop in the U.S. is going to have a 31x10.5...
Overland-Indiana
Kokomo
I'm with @Shizzy I would strongly consider how easy you can get another tire if yours get trashed.. I went with 31's instead of 32's also, just for popularity and ease of replacement.
58-fc170
Unless you like a thump, thump ride for the first few miles when cold I would steer clear of the bias tires.
Also a stock rim is something around 4.5 inches wide, no way a 31x10.5 would fit safely on that.
A 175/75R16 is the closest common replacement for a 6.50-16.
