[SOLD] Restored 1947 Bantam Overland Trailer For Sale $6,000 [Huntsville, AL]
UnderrLanderr
Huntsville, AL, USA
Cam
Ash
This is a fully restored 1947 Bantam T3-C trailer, restored September 2019. BFG KM3s are 7.50 R16 LT Load Range E mounted on period correct welded steel Bantam 5 on 5.5 bolt pattern wheels. Spare Koyo wheel bearings and tent cover included. The trailer is very light, likely in the 7-800lb range empty. Color is the official Jeep color from 2013 models only (Commando Green) with professionally applied black bedliner inside, underneath, and to the frame and fenders. It is very well protected from the elements. LED lighting, all new wiring, and original replacement Grote reflectors. The lid seals the trailer contents very well from the elements and the entire tub is lockable with 2 key locks on the tailgate. The tongue was replaced with much stronger than original C channel and 2" square tubing so an articulating offroad hitch can be used if desired. Spare tire mount is incorporated into the tongue. The tent is a Tepui Kukenam 4 Ruggedized and is in perfect condition.
I am firm on the price, local pickup only.
UnderrLanderr
Huntsville, AL, USA
Cam
Ash
Available? Can the wheels/tires/hubs be switched out for Toyota 6 lug and BFG KO2's?
It is still available. The tires are KM3s right now and can be switched to whatever you want. The axle was swapped out with an aftermarket axle and toyota wheels won’t fit on it in its current configuration but I’m sure that you could swap it to a Toyota axle if you wanted to.
JGH
Dallas, Dallas County, Texas, United States
John (JG)
Hudik
Brand of axle? Dexter? I want to research axle and wheels to fit Toyota
