Solar Power and Overlanding
What kinds of electricity setups are you guys running while off the grid? I'm looking at it for basic needs, charging devices, running small things, etc... I'm not sure what a whole setup looks like. I'm not trying to run a fridge or microwave or anything silly like that. Thanks for any input, semper Fi.
Jeremy
Reactions: Kelly
lost again...
Lorain County, OH, USA
None
Reactions: Wawa Skittletits
Hi Jeremy and Rebecca,
I saw your intro post. We used to live down the road from you in Locust Grove, by the Wilderness battlefield.
Here are links to a couple previous discussions on solar power that you might find helpful.
Welcome aboard,
solar power
SOLAR PANELS AND CHARGERS
Renogy 100 watt Solar Suitcase Review
Gear Review on Overland Solar System
Solar Power?
Thanks Steve, I figured there were some threads you guys could point us to. We have a jeep as well, I know a ton about offroading and rock crawling, but the overland game is new to me
Jeremy
Reactions: Steve
Mad Garden Gnome
Templeton, Ca
Ryan
Marlett
W6ORV
We have a 100W panel and controller we use on our horse trailer for camping. It supports two big AGM batteries, which supported a 40Q Edgestar cooler set sub 30F (4.5 amps) out at a desert festival for a week. We got the whole package from WindyNation. The controller is straight forward. I will go with them again if I decide to build my overland trailer.
Reactions: Glenn
MOAK
Donald
Diehl
WRPN 506
I would suggest that you always get a panel bigger than you think you may need. It has been said, on many forums, that all that is needed is an 80 to 100 watt panel to power our fridge, charge up our camera batteries, laptop, phones, and keep our dual battery system topped off. For just a litle more money, I went ahead and bought a 125 watt panel. No regrets.
The other Sean
Minneapolis
I agree. like most things in life, it never hurts to see how much "the next step up" is. Sometimes it is not much more to get much more...
Ed B
Riverside, Ca. 92506
I have the Overland Solar 90 W panels and have been very happy with them. Use them to charge a Die Hard Platinum in an ArkPak battery box and a couple of Odysseys when using my utility trailer. Run an ARB fridge and keep several electronic devices charged when on trips.
RaggedViking
Readsboro, VT
I've been using Goal Zero products for a while now. I first got introduced to them when I was working for Thule and had a full solar array hooked into the truck - mostly to power all of my test equipment. Since then, I've picked up their Yeti 400 and Nomad 100 panel and use those quote a bit on the trail, at camp, etc. I know there have been a lot of innovations and their might even be better options out there, but their gear is easy to use - familiar to me - and I can't beat it. I also have their Venture 30 and Sherpa 50 which are smaller packs I use for smaller items if I leave camp and hike out for a day.
Reactions: Kelly
I saw the goal zero products on the interwebs, was kind of skeptical, but then saw a friend post them up on FB today, and now you're mentioning them. Looks like they are worth checking out, thanks.
Jeremy
Reactions: RaggedViking
RaggedViking
Readsboro, VT
Jeremy
I think they are. They put a lot of research into everything they do and they've got a lot of financial backing to explore new and better ways of collecting and storing solar power. A lot of the competition uses panels created by other companies - but GZ uses all of their own stuff. They're also owned by one of the largest commercial and residential solar companies in the country, so that helps. Haha
E
expeditionnorth
Guest
if you live in an area where the sun may not always be out I say a 2nd AGM battery and charger in series that can be removed or charged as needed
off the 2nd battery run an inverter in the rig
its less gear to haul in the end
Captain Josh
Mid-Michigan
Josh
Fornwall
W4WOL
This does look like a nice set of kits, but they seem to be marketing more as battery chargers/backups versus being a power supply system. Who are they owned by?
RaggedViking
Readsboro, VT
They're owned by NRG.
I think battery back ups and supply systems could be synonymous to a certain point.
I don't know at which point the overlap stops and the devide between back up power and power delivery begins, but I do know that even the new power packs coming from GZ only go up to 1500-1800 watts.
Reactions: Captain Josh
Bates City, MO, USA
Heiser
I run the renogy 100 watt suitcase to power my arb off of my truck batteries. It works well but I am now thinking about doing a dedicated battery for just the fridge...
Captain Josh
Mid-Michigan
Josh
Fornwall
W4WOL
You are absolutely right! My thought was along the lines of portable (i.e. handheld) versus something that you have to more tightly integrate with your rig. But as you say, the lines are blurry either way. I have a lot of other mods to do before I get that far, but solar is definitely on the list!
RaggedViking
Readsboro, VT
Those are my thoughts too. They could be the same thing - marketed differently.
Who knows? As long as they power the things that need power!!!
Flipper
Florida
F
We have a 100W solar panel with a Morningstar controller , 2 AGM group 31 batteries. Also an BlueSeas battery link, this charges the AGMs off the trucks alternator, when you start the truck the link connects the batts, when you turn the truck off it disconnects so you don't have to worry about having a dead start batt. It is also equipped with a 20A Xantrex charger that can be plugged into AC at the campsite or a Yamaha 2KW inverter, everything marine grade with marine wire and lugs. This all goes to a Kisae 2KW pure sine wave inverter that powers everything. I used to do high end marine electronic and electrical installs before I retired so if anyone has any questions give me a shout I will be glad to help.
Reactions: Rubiconcruiser
LostInSocal
Chino Hills, CA, US
I have a Goal Zero Yeti 400 which I charge using the onboard 12V when we're driving. It's plenty for what we need, and so far I'm not left wanting. Beyond that, I have a couple of folding solar panels to charge phones, small devices, and battery packs when we're in camp. Generally, power isn't an issue for us when we're out there.
Rubyredfozzy
Benefactor
3,771
Fort Mitchell, AL, USA
Aaron
Welch
I agree with the posts above. I have run a Goal Zero for a while. I just have a small set up that can attach to my backpack while I'm hiking or I can set it out on the hood of the car. It can charge directly to an item or I run it to the back up battery pack. The solar panel also has different plugs so you have a variety of plug in options. nomad20-pdp-1000x667_sm.jpgnomad20-iphone_sm.jpg
Cort
Trail Blazer III
5,197
Grand Rapids
Cort
Beard
KD8GQL
I have a GZ Yeti 400 with 4 boulder 30 watt panels. I’m super happy with the yeti but I’ve never gotten more than 60 watts out of the 4 of them combined. Is this normal?
Reactions: Andy G
