Snorkel in winter
ScottVinson1766
Parker, CO
Quick question for anyone running a snorkel in snow country. I put a safari snorkel on my Tacoma and am curious what people are doing to keep snow out of it while it has to sit parked outside in a storm. I understand I can turn ram around while driving, just worried about while it's outside while I'm at work. TIA.
Daniel Etter
Fishers, IN
Dan
Etter
Could always tie a grocery bag over it if you don't want to turn the top. Just don't forget to take it off when you leave! I have never had an issue by turning the top of mine though.
Reactions: ScottVinson1766
VCeXpedition
Torrance, L.A., Cal., Earth
Dan
Rich
K6DHR
It's a fair question. I have to say I have never heard of any issues from snow accumulation while sitting. Anecdotally, this has not been a topic of discussion as far as I could find but you might search other forums, particular to your car.
One way to check to see if running your scoop facing forward in a snow storm is, just after driving, pull into a safe place and see if you have any moisture accumulation on your air filter. Then turn the scoop around and see if it improves.
I'll bet you don't need to do it but I'm not a big fan of snorkels or cold air intake for that matter. Too much OEM blood in my system.
Post back up to share what you find.
Maxterra
West Haven, Utah
Dave
Horting
Running mine for 5 or 6 years now and a few heavy storms without any problems (same with rain).
Maybe a bit wet in the bottom of the box on the entry side underneath the filter, but filter always seemed dry and nothing above the filter on the intake side.
Captain Josh
Mid-Michigan
Josh
Fornwall
W4WOL
This is something I hadn't ever considered... how bad would the snow have to be blowing for your snorkel to accumulate all that much? Especially if you're worried about when you're parked?
