Seating a tire bead
05EXCURSION
Renton, King County, Washington, United States
Jason
Lujan
Well lost the bead on the excursion after airing down to low couldn't get the bead to seal so I used some lotion to fill the gaps in the bead and it was able to take some air. Who would of thought a bottle of lotion would help seat the bead.
Ontario California
SMR
KO6BI
I've rinsed the bead with water to get the dirt out then reseated it. If your careful you don't get water in the tire. This was common, pre bead locks. Never tried lotion though.
Bad Sport
National City, CA, USA
Lyle
Mardis
US Navy
I've used soapy water. In addition, you can put a ratchet strap around the circumference of the tire. As you tighten the strap it forces the beads out toward the rim which helps seat them.
old_man
Loveland, Colorado
Tom
Houston
WØNUT Extra
Back on the farm we would put an M80 in the big tractor tires to pop them.
  • Wow
Reactions: 9Mike2
