Review TRE Snatch Block
Jeff Graham
Benefactor
4,551
Splendora, TX, USA
Jeff
Graham
Army Vet
In my thread Overland Weight Reduction:
https://www.overlandbound.com/forums/threads/overland-weight-reduction.8390/
We have been exploring ways to reduce the load we carry with our vehicles. I have been going through my gear piece by piece, exploring options to reduce weight. I discover a Snatch Block made by TRE
https://tacticalrecoveryequipment.com/product-category/snatch-block/
This block is very light, less then 2 lbs. each. Since I carry 3 snatch blocks, this was an opportunity to reduce a lot of weight. I purchased three of the snatch blocks. Before I retired my old snatch blocks, I decided I needed to put the new ones to the test
I want to my Local off road park, Hidden Falls Adventure Park.
http://www.hiddenfallsadventurepark.com/
I wanted to put the snatch blocks through their paces. I parked my jeep on one of the steepest hills in the park. To provide some additional resistance, I added some drag by applying my parking break. I first used a double line pull rig, one of the most common self recovery rigs. I secured the TRE Snatch Block with a Bubba Rope soft shackle and tree saver.
The first thing I noticed, is how easy it was to work with the much lighter equipment. it has smooth edges, to accommodate for soft shackles.
After doing a final safety check, to ensure there was no one around that could be injured. I sat in my jeep, with the winch switch, and started the pull. With the forces on the winch, it easily pulls me up the hill. I applied the parking break a bit more, to increase the resistance. The Snatch Block took the loads with no issues. It pulled the jeep up the hill, with all 4 tires dragging.
I decided it was time to add some additional force on the Snatch Block, so I rigged a single line recovery. The first test, was a 2/1 ratio. the second test, is a 1/1 ratio, so increases forces on the Snatch Block. I repeated the same process. After doing a safety check, to ensure there was no one around that could be injured. I sat in my jeep, with the winch switch, and started the pull. The same experience, even with tires dragging, the snatch blocked held strong.
I inspected the Snatch block for any visual signs of stress. Everything seems to be in order, I detected no bending or binding in the snatch block. I'm happy with my results, and will replace my current steel Snatch Blocks for these new TRE light weigh blocks.
Corbet
Durango, CO
Corbet
Hoover
Thanks for the review, I have been looking at those myself.
