Question about tires.
DaneFloyd
Hockley, TX, USA
Dane
Floyd
Question for all of the experts on here (no sarcasm intended).
If you put a 3 inch lift on a suburban what type of tires would you go with? Not looking to go anywhere too crazy.
Thanks
Owen Sound, Ontario, Canada
James
Girard
Thanks
Is this a question on size or tread pattern?
Lift companies will generally give a recommendation on a size of tire to run with a certain wheel offset and you can work off of that.
If it's a question of tread type, I would probably go with a decent A/T tire over an M/T to save the noise and a little bit of extra wear.
If you are looking at brand recomdations you will get every tire under the sun recommend because it is going to be very terrain specific and vehicle specific recommendations.
DaneFloyd
Hockley, TX, USA
Dane
Floyd
Tread pattern. Brand will just have to be in the budget.
Thanks
Reactions: Red_Leaf_Overland
Smileyshaun
Happy Valley, OR, USA
Shaun
Hoffman
Tread pattern has a lot to do with what you want out of the tire , more off-road , more street manners , tire noise , terrain you will encounter ect ect ect . As far as size well that’s all debatable and dependent on the tire itself( not all tires of the same size are actually the same size , wheel offset and willingness to trim . I have 35s on my GMC Sierra with only 2” of lift but they fit with no lift because they are only 10.5” wide . This post will turn into a very long “ my setup is the best “ post so my best advice to you is get on some forums specific to your rig and do allllooooootttt of reading to weed out the good info .
MidOH
Mid Ohio
Clark
YourHighness
Correct tread, armored sidewall, thick Rubber to shrug off rock and impacts. Winter rated.
Mild = Cooper ST Maxx
Good = Cooper STT Pro, Maxxis Rzr.
Aggressive short range or deep snow = Irok's.
Avoid AT's. Most are nothing more than street tires with funky tread.
Smileyshaun
Shaun
Hoffman
I guess as with all things it depends on where you go , I have the opposite thought unless it’s a trail rig avoid MT tires at all costs and stick with AT tires .
This is why asking what tires to buy would be like asking a group of people what pizza you should eat everybody like something different for different reasons.
Trail_pilot
James
Girard
It doesn't seem like the OP will likely need anything nearly as aggressive as most of those tires lol. Maxxis rzr and Iroks would be way over the top for "Not looking to go anywhere too crazy".
Reactions: Armor_LG
Armor_LG
Cincinnati, Ohio
Luke
Glischinski
Whatever tires you go with, I like to recommend to look at the weight of the tire compared to others of the same size. More weight = worse gas mileage. I also like to get tires with the 3PMSF symbol so I know they are tested to perform adequately in adverse weather conditions.
DaneFloyd
Hockley, TX, USA
Dane
Floyd
Trying to parse through all of the information now.
MidOH
Mid Ohio
Clark
YourHighness
It was a post for everyone.
But in this case the OP will be best off with the ST Maxx. Same tough armored carcass of the proper STT's, but milder, quieter tread pattern. Keep a set of tire chains or Truck Clawz handy for mud and deep snow.
Keep in mind that the new breed of MT's are very streetable. The STT's and Rzr's do fine on the street in snow and rain.
James
Girard
I've never heard of the ST Maxx before. I'll have to look into them and see if I can get them in my size because I do like me a Cooper tire.
Smileyshaun
Shaun
Hoffman
I had fantastic luck with the cooper discover at3-4s , whisper quiet on the highway, 3peak rated and worked wonderfully in the ice . St maxx works great in the snow , tuff sidewalls do need to be aired down a bit more than normal started to get noisy as they wear .
Asuarez_673
Virginia Beach, VA
Alexis
Suarez
it all depends what you're trying to do? if you're looking for an overall decent daily with off road capabilities, I would do a A/T tire. I've had really good luck with Cooper Discover AT3. if you're looking for something that will give you an okay dailiness but be better off road, then I would look more at a M/T tire. Personally I really like the Toyo M/T, right now I'm running the BFG KM3. it all really narrows down to your preference and of course budget
MarioT'sCJResto
12157
Christopher
Laboy
As already recommended I would go with the A/T over a M/T tire, I run KO2's on my CJ5 and I run Pro Comp A/Ts on my Ram. Everyone has their own personal preference here, so I would just do your research. I was looking for a 10ply A/T for my Ram when I switched from BFG to ProComp.
