E
expeditionnorth
Guest
I want the ability to carry 2 spare tires for my yukon when out in the middle of no where
one will be the soon rear tire carrier for the rear of my rig & this one
OK I didnt like the previous design I had tacked in place
so this morning I got (1) 20"X2'X1/8" square tubing and another by 1'
when I arrived at my parents my dad informed me that we had been robbed, my 7" grinder & 4" grinder plus a bunch of his tools were missing
so I had to go buy another...
& as such I cut off all the old pieces & began on this
the cheap flux core wasnt too bad, my biggest problem again was the welding helmet, I couldnt get it to stay in place
sorry for the chainlink fence in the background, but I thought it was going to downpour so I waited till i was done for pics
decided to leave about 2" of this piece on to tack to and hopefully hold the upright leg, you can see my bubblegum welds from this winter, where I couldnt see through the helmet
also had the same problem this time, so I tore off all the protective plastic that was lining the inside lens & WOW I could now see, except its moving...
wasnt a bad bead, but could be better
by trial & error I learned #4 on the speed dial was perfect
Looked like rain approaching so I finished it off quick like, still need to go over some welds once more & my dad brought out some black paint to cover it up to prevent rust (hopefully)
on this plate the tire will attach, I need to measure the lug hole center, drill & so forth at a later date
on the back of the upright & the horizontal piece I added some 2" flat stock to cover that open hole & to tie things together a bit
& it completed (almost) from a distance
I had my dad give it the pull & tug test, it shook the whole trailer, so I think it'll hold the tire safely, not pretty but functional
