LR Discovery roof rack
davis31052
Awendaw, South Carolina, United States
Eddie
Davis
U.S. Marines
View attachment 22432 Anybody familiar with the rack pictured. Looks like a factory accessory and I can't determine from the picture if it's multiple pieces. Present owner isn't sure. I'm thinking of picking it up but I hate to pull a trailer 3hrs if it'll break down and fit in my 4 Runner.
4xFar Adventures
Benefactor
4,826
Monterey, CA, USA
Brenton
Corns
That's a Safety Devices rack (from the factory). The Baja Rack has more uprights under the top bar. The best way to tell if it's an SD rack is by looking at the mounting feet. They have an Allen head bolt going up (vertically) in the center, and two bolts on either side to clamp the outer plate to the rack. This pic is from the time I repainted the rack, hence the bare steel.
Reactions: Zargon
4xFar Adventures
Benefactor
4,826
Monterey, CA, USA
Brenton
Corns
Oh, there is a difference between a Discovery 1 and Discovery 2 SD rack. The D2 version is about 6" longer than the D1, and will overhang the rear of a D1.
Reactions: Zargon
Kevigizmo
Western Europe Moderator
North Walsham, Norfolk, UK
Kevin
Titmarsh
indeed a D1 is shorter than a D2 as mentioned above by about 6 inch or so,
Most roof racks which were designed for D1 or D2 will work with eachother,
I have a rack which was fitted for a D1 but the roof mounts do extend that little bit to then fit on my D90 - which proves a D90 is about 2 inch wider at the roof gutter than a Discovery :grinning:
Reactions: 4xFar Adventures
