This trailer is the Backout addition. It has larger tires and a stronger suspension. You can camp and haul your toys on the trailer. Sleeps 4.
It has the following options.
Sink, Lamp Post, Awning, Water storage, ATV blocks, Table,
Trailer Dimensions Overall: 92" wide x 144" long
Upper Deck Dimensions (between rails): 76" wide x 107" long
Inside Trailer Bed Dimensions: 68" wide x 99" long
Deck Height: 40.5"
Upper Rail Height: 44.5"
Utility Wall Height: 52"
Coupler Ball Size: 2" ball
Coupler Height: 20” from ground to top
Lights: LED, recessed to avoid damage
Electrical: Seven-way round plug
Gross Axle Weight Rating (GAWR): 3,500 lbs. torsion axle
Gross Vehicle Weight Rating (GVWR): 2,995 lbs.
Total Weight: (tent, trailer and frame) 1,245 lbs.
Trailer Weight / Tent & Frame Weight: 995 lbs./ 250 lbs.
Tongue Weight: 155 lbs.
Tire Size: LT 235/85R16
Rim: 16” Black Aluminum Alloy
Ground Clearance: 15.5”
Lug Pattern: 5 on 4 ½
Cold Tire Pressure: 80 psi
Electric Brakes: Optional
Wheel Well step plates
Multiple Tie Downs
Front Gate: for Utility Mode
Powder Coated Frame
Deck Height: 40.5"
Multiple Tie Downs
Powder Coated Frame
