Lifting your Rig?
MOAK
Donald
Diehl
WRPN 506
Many folks on here have posted up about lifting their rigs. I've always commented that 2 - 2.5"s is plenty enough for an overlanding rig to traverse 99.9% of all trails in North America, provided you have lockers, at least in the rear axle. Anything higher will cost you upwards of a thousand dollars an inch to get it right. Not only must you radically correct your suspension geometry, you gotta get the driveline geometry corrected as well... Here is a great video explaining a bit of physics on driveline geometry. Enjoy. !!
I agree! 2-2.5" is plenty. Any more than that, and the cost becomes insane. Not to mention a short lift still can retain stock components, which are generally cheaper and more readily available. I myself have about a 2" lift and plan on running 30-31" tires. I know I can make it over most obstacles with that setup and without having to trim anything
Awesome information. You learn something every day. Thanks.
I've always been on the train of thought that with IFS a 1-1.5" body lift and a small amount of trimming/love with a bfh is way more beneficial than lifting the suspension due to most lifts limited suspension travel. tall skinny tires are also a good way to get more tire with less lift .
I think most people get overlanding and wheeling confused , you can do a amazing amount of overlanding in a car on forest service roads probably a good 80-90% of them. It's when you want to tackle that harder 10% of the really bad roads that you need to rethink your suspension and tires .
I love this video. I myself have a 4 1/2 inch suspension lift and a 1 inch body lift. My drive line angles are fine. I run 33 inch tires. I travel all over the Country to do both wheeling and over landing. There are very few roads or trails I have come across that have been impassable for me. I see many vehicle that have much larger tires, then complain that they only get 10 miles to gallon. If you totaly change the aerodynamics of a rig and shove it 7 or 8 inches in the air it is going to effect fuel mileage.
