Pathfinder II
I'm about to install a new roof rack, and redo all the wiring for my LED lighting.
Due to having to pull wire through small spaces, be efficient, and make it easier to pull the wire... I was wondering if anyone a little more experienced could help out.
I stumbled across this PDF that seems to be the information that I'm looking for, though I'm hoping that someone can confirm.
http://www.sunforceproducts.com/Support Section/Solar Panel & Charge Controllers/WireGaugeSelectionTable.pdf
All the LED's are VisionX, from the same series, purchased at the same time. So I can safely assume that they're all the same 5w per LED.
I have..
The follow up question is. Since they're all going to a common ground point, is there any reason I can't combine the ground wires to save some space if I do the math with the totals in the chart, or might that cause damage or other interference with communications and audio..?
Any insight would be greatly appreciated.
I have..
- 4 lines that will be 15w/1.25A@12v
- 1 that will be 30w/2.5A@12v
- 1 that will be 135w/11.25A@12v
- x4 20 Gauge
- x1 18 Gauge
- x1 16 Gauge
