You’re awesome, thank you so much. I’ve got a t-case drop in already, and I’m lifted 3”, but it’s a Rough Country add-a-leaf that the PO installed, and I want to rebuild it with better parts. I like most of the parts you used, so I’ll probably just copy your setup. As for the disc brakes, were the parts very expensive, and was it a straight-forward install? Any modification or fabrication needed, other than the e-brake? Again, thanks so much for this info, it’s greatly appreciated. I’ve had this Jeep a year and only changed the wheels and done some maintenance/replaced old parts. It’s going to be time to rebuild bits of it to make it more suitable for longer trips.
