So the venerable farm jack aka hi lift is only rated for 4000 lb with a max load test of 7000lbs from the factory. What jack would you use on a lifted truck that weighs 8500 lbs fully loaded? I dont trust farm jacks much and I'm a farmer, ive seen them knock folks teeth out and drop tractors on legs also on the truck there is nowhere i can jack without damaging something . Should i just make a skid plate for a extended lift hydraulic floor jack or go with an exhaust jack rated for 8800lbs? Right now i have to use the spare tire under the factory bottle jack to get wheels off the ground but that jack is about ready to let go after rotating the tires a few times. I already have a hi lift for farm use but like i said it is under rated for my needs and super sketchy on anything over 4000lbs
