I not showing up oh map.
Kevigizmo
Western Europe Moderator
North Walsham, Norfolk, UK
Kevin
Titmarsh
Hey @Sumpunker / @HAT608
There are a couple things to try:
Top Left - Username > Personal Details
Ensure that the location you want to show on the map is written in the field named : Location
you can verify it is correct by copy and paste into Google Map, where that shows on google map, should show on the member map
second
Top Left - Username > Privacy
Check the settings at the bottom of the page:
Enable "Mark my position on map:" and select "My entry location" (as this will pull info from the steps above)
Then the next option below "Point my location randomly on map:" you can enable or disable which points your true location anywhere within a radius randomly
Please note that the Map only updates ONCE per day at midnight PDT as a snapshot
If you continue to see issues please reach out to @Steve or @Michael who can take a deeper look into it for you
All the best
sully3
Purdy, MO
jeff
sullivan
I am also no longer showing that I'm on the map have tried to make sure things are put in correctly but no change, need help..
I was on it before not sure why I disappeared..
