I have read that you need to size the rope based on the weight of the vehicle you want to recover. However I understand there is a formula, i.e. 3x the weight of you vehicle.
So, when searching for a rope, I get 7/8in rated from 21K up to 30K lbs. 1in seems to be 33K+.
GVWR of my 2008 2500 Suburban is 8,600lbs. This puts me at 25,800lbs.
My concern is that the 7/8in ropes are all 7/8in, but have ratings from 21K to 30K. Are some sellers being overly generous on the rating? The 1in is too much, but none are rated below 30K.
Am I fine to get a 7/8in and just make sure the rating is at least 26K, or should I just get the 1in. I have also read that going too big is bad as it will not act like a kinetic rope, but more like a stiff strap loosing the kinetic advantage.
